[petsc-users] When pull the petsc-dev for update:Connection timed out
Alan zhenglun.wei at gmail.com
Sun Nov 25 12:48:44 CST 2012
Dear Sean,
> On Sun, Nov 25, 2012 at 12:30 PM, Alan <zhenglun.wei at gmail.com> wrote:
>> Thanks Sean,
>>       my /petsc-dev/.hg/hgrc shows:
>> [paths]
>> default = https://bitbucket.org/petsc/petsc-dev
>> [hostfingerprints]
>> bitbucket.org = 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b
> Good.
>>       When pulling the petsc-dev, it shows:
>> abort: no certificate for bitbucket.org with configured hostfingerprint
> Weird. Are you behind a proxy?
It is. The server is behind a university net.
>>       The same thing happens if it pull the BuildSystem with:
>> [paths]
>> default = https://bitbucket.org/petsc/buildsystem
> Something is being misconfigured because I'm guessing that buildsystem
> is trying to pull petsc-dev or vice-versa. Let's be sure, by
> $ cd $PETSC_DIR
> $ hg showconfig paths.default
It shows:
> $ cd config/buildsystem
It shows:
> And might as well send your mercurial version, too,
> $ hg version
Mercurial Distributed SCM (version 1.8.3)
(see http://mercurial.selenic.com for more information)
Copyright (C) 2005-2011 Matt Mackall and others
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Thanks for you help, Sean.
Alan
