[petsc-users] Fwd: error messages while updating petsc-dev
A.L. Siahaan als88 at cam.ac.uk
Thu Nov 8 14:11:44 CST 2012
Sorry...I thought the previous email was replied to me.
It has similar subject.
Antony
On Nov 8 2012, Satish Balay wrote:
>Antony,
>perhaps you are replying to the wrong e-mail thread.
>satish
>On Thu, 8 Nov 2012, A.L. Siahaan wrote:
>> Hi,
>> These are the outputs :
>> antony at gnw20pc1:~/code/petsc-dev$ hg parent
>> changeset:   24846:6e281c3f1f72
>> tag:         tip
>> user:        Matthew G Knepley <knepley at gmail.com>
>> date:        Thu Nov 08 11:41:01 2012 -0500
>> summary:     Manual: Added part of a section on DMComplex
>> antony at gnw20pc1:~/code/petsc-dev$ hg tip
>> tag:         tip
>> antony at gnw20pc1:~/code/petsc-dev$ hg status ? configtest.mod0
>> antony at gnw20pc1:~/code/petsc-dev$ hg pull pulling from
>> http://petsc.cs.iit.edu/petsc/petsc-dev searching for changes no changes
>> found pulling from http://petsc.cs.iit.edu/petsc/BuildSystem searching
>> for changes no changes found antony at gnw20pc1:~/code/petsc-dev$ hg update
>> 0 files updated, 0 files merged, 0 files removed, 0 files unresolved
>> antony at gnw20pc1:~/code/petsc-dev$ cd config/BuildSystem/
>> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg parent
>> changeset: 2878:3d4bb7478b00 tag: tip user: Barry Smith
>> <bsmith at mcs.anl.gov> date: Wed Nov 07 20:34:01 2012 -0600 summary: added
>> support for --with-PACKAGENAME-pkg-config[=pathtosearch]
>> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg tip changeset:
>> 2878:3d4bb7478b00 tag: tip user: Barry Smith <bsmith at mcs.anl.gov> date:
>> Wed Nov 07 20:34:01 2012 -0600 summary: added support for
>> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg status
>> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg pull
>> no changes found
>> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg update
>> Regards,
>> Antony
>> > please copy/paste the output of the following commands
>> > hg parent
>> > hg tip
>> > hg status
>> > hg pull
>> > hg update
>> > hg status
>> > hg parent
>> > hg tip
>> > hg status
>> > hg pull
>> > hg update
>> > hg status
>> > Satish
>> > On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
>> > > Thanks for your reply, Dr. Balay.
>> > >      However, I do not know how to get the latest version of
>> > > petsc-dev except following
>> > > http://www.mcs.anl.gov/petsc/developers/index.html
>> > > |cd petsc-dev||
>> > > hg pull -u
>> > > ||./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>> > > ||make
>> > > Those are all what I did. Should I do something else?
>> > > thanks,
>> > > Alan
>> > > > > > Dear folks,
>> > > > >      I came across an error while making a code:
>> > > > >   makefile:7: *** missing separator. Stop.
>> > > > >      This happens after I was tying to update the petsc-dev
>> > > > > with > >
>> > > some error message; the configure.log, error.log and make.log are >
>> > > > attached. I've already sent it to petsc-maint list. Is this
>> > > makefile > > error related to the fail update?
>> > > >       This is a Mercurial clone
>> > > >          Defined "VERSION_HG" to
>> > > > ""85e6055943e0711fccdec2d08caeba48971d3d55""
>> > > >          Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14 2011 >
>> > > -0700""
>> > > >          Defined "VERSION_BS_HG" to
>> > > > ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
>> > > >          Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16 17:33:47
>> > > > 2011 >
>> > > +0200"" <<<<<
>> > > > > You don't have the latest petsc-dev. Can you pull the latest >
>> > > petsc-dev and retry?
>> > > > > Satish
