[petsc-users] Fwd: error messages while updating petsc-dev
Thu Nov 8 14:02:52 CST 2012
Antony,
perhaps you are replying to the wrong e-mail thread.
satish
On Thu, 8 Nov 2012, A.L. Siahaan wrote:
> Hi,
> These are the outputs :
> antony at gnw20pc1:~/code/petsc-dev$ hg parent
> changeset:   24846:6e281c3f1f72
> tag:         tip
> user:        Matthew G Knepley <knepley at gmail.com>
> date:        Thu Nov 08 11:41:01 2012 -0500
> summary:     Manual: Added part of a section on DMComplex
> antony at gnw20pc1:~/code/petsc-dev$ hg tip
> tag:         tip
> antony at gnw20pc1:~/code/petsc-dev$ hg status
> ? configtest.mod0
> antony at gnw20pc1:~/code/petsc-dev$ hg pull
> pulling from http://petsc.cs.iit.edu/petsc/petsc-dev
> searching for changes
> no changes found
> pulling from http://petsc.cs.iit.edu/petsc/BuildSystem
> no changes found
> antony at gnw20pc1:~/code/petsc-dev$ hg update
> 0 files updated, 0 files merged, 0 files removed, 0 files unresolved
> ? configtest.mod0
> antony at gnw20pc1:~/code/petsc-dev$ cd config/BuildSystem/
> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg parent
> changeset:   2878:3d4bb7478b00
> tag:         tip
> user:        Barry Smith <bsmith at mcs.anl.gov>
> date:        Wed Nov 07 20:34:01 2012 -0600
> summary:     added support for --with-PACKAGENAME-pkg-config[=pathtosearch]
> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg tip
> tag:         tip
> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg status
> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg pull
> no changes found
> antony at gnw20pc1:~/code/petsc-dev/config/BuildSystem$ hg update
> Regards,
> Antony
> On Nov 8 2012, Satish Balay wrote:
> > please copy/paste the output of the following commands
> > hg parent
> > hg tip
> > hg status
> > hg pull
> > hg update
> > hg status
> > hg parent
> > hg tip
> > hg status
> > hg pull
> > hg update
> > hg status
> > Satish
> > On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
> > > Thanks for your reply, Dr. Balay.
> > >      However, I do not know how to get the latest version of petsc-dev
> > > except following http://www.mcs.anl.gov/petsc/developers/index.html
> > > |cd petsc-dev||
> > > hg pull -u
> > > ||./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> > > ||make
> > > Those are all what I did. Should I do something else?
> > > thanks,
> > > Alan
> > > > > > Dear folks,
> > > > >      I came across an error while making a code:
> > > > >   makefile:7: *** missing separator. Stop.
> > > > >      This happens after I was tying to update the petsc-dev with > >
> > > some error message; the configure.log, error.log and make.log are > >
> > > attached. I've already sent it to petsc-maint list. Is this makefile > >
> > > error related to the fail update?
> > > >       This is a Mercurial clone
> > > >          Defined "VERSION_HG" to
> > > > ""85e6055943e0711fccdec2d08caeba48971d3d55""
> > > >          Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14 2011 >
> > > -0700""
> > > >          Defined "VERSION_BS_HG" to
> > > > ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
> > > >          Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16 17:33:47 2011 >
> > > +0200"" <<<<<
> > > > > You don't have the latest petsc-dev. Can you pull the latest >
> > > petsc-dev and retry?
> > > > > Satish
