[petsc-users] How to use multigrid?
Sat Nov 3 12:08:26 CDT 2012
1. What kind of equation are you solving? AMG is not working well if it
takes that many iterations.
2.
*      #                          WARNING!!!                    #*
*      #   This code was compiled with a debugging option,      #*
*      #   To get timing results run ./configure                #*
*      #   using --with-debugging=no, the performance will      #*
*      #   be generally two or three times faster.              #*
On Sat, Nov 3, 2012 at 12:05 PM, w_ang_temp <w_ang_temp at 163.com> wrote:
> (1)  using AMG
> [0]PCSetData_AGG bs=1 MM=7601
> Linear solve converged due to CONVERGED_RTOL iterations 445
> Norm of error  0.2591E+04 iterations   445
>   0.000000000000000E+000  0.000000000000000E+000  0.000000000000000E+000
>  -2.105776715959587E-017  0.000000000000000E+000  0.000000000000000E+000
>    26.4211453778391      -3.262172452839194E-017 -2.114490133288630E-017
> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
> -fCourier9' to print this document            ***
> ---------------------------------------------- PETSc Performance Summary:
> ./ex4f on a arch-linux2-c-debug named ubuntu with 4 processors, by ubu Sat
> Nov  3 09:29:28 2012
> Using Petsc Release Version 3.3.0, Patch 4, Fri Oct 26 10:46:51 CDT 2012
>                          Max       Max/Min        Avg      Total
> Time (sec):           3.198e+02      1.00002   3.198e+02
> Objects:              4.480e+02      1.00000   4.480e+02
> Flops:                2.296e+09      1.08346   2.172e+09  8.689e+09
> Flops/sec:            7.181e+06      1.08344   6.792e+06  2.717e+07
> Memory:                2.374e+07      1.04179              9.297e+07
> MPI Messages:         6.843e+03      1.87582   5.472e+03  2.189e+04
> MPI Message Lengths:  2.660e+07      2.08884   3.446e+03  7.542e+07
> MPI Reductions:       6.002e+04      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N
> --> 2N flops
>                             and VecAXPY() for complex vectors of length N
> --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 3.1981e+02 100.0%  8.6886e+09 100.0%  2.189e+04
> 100.0%  3.446e+03      100.0%  6.001e+04 100.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>  &n bsp; Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
>       %T - percent time in this phase         %f - percent flops in this
> phase
>       %M - percent messages in this phase     %L - percent message lengths
> in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops o ver all processors)/(max time
> over all processors)
>       #                          WARNING!!!                    #
>       #                             & nbsp;                          #
>       #                                &n bsp;                       #
> Event                Count      Time (sec)
> Flops                             --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> MatMult             6291 1.0 2.1431e+01 4.2 1.01e+09 1.2 1.9e+04 3.4e+03
> 0.0e+00  4 42 86 85  0   4 42 86 85  0   170
> MatMultAdd           896 1.0 4.8204e-01 1.1 2.79e+07 1.2 1.3e+03 3.4e+03
> 0.0e+00  0  1  6  6  0   0  1  6  6  0   208
> MatMultTranspose     896 1.0 2.2052e+00 1.3 2.79e+07 1.2 1.3e+03 3.4e+03
> 1.8e+03  1  1  6  6  3   1  1  6  6  3    45
> MatSolve             896 0.0 1.4953e-02 0.0 2.44e+06 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   163
> MatLUFactorSym         1 1.0 1.7595e -04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatLUFactorNum         1 1.0 1.3995e-0423.5 1.85e+04 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   132
> MatConvert             2 1.0 3.1026e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
> MatScale               6 1.0 8.9679e-03 5.7 3.98e+05 1.2 6.0e+00 3.4e+03
> 4.0e+00  0  0  0  0  0   0  0  0  0  0   158
> MatAssemblyBegin      37 1.0 2.1544e-01 1.7 0.00e+00 0.0 5.4e+01 6 .4e+03
> 4.2e+01  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd        37 1.0 2.5336e-01 1.4 0.00e+00 0.0 9.0e+01 6.8e+02
> 3.1e+02  0  0  0  0  1   0  0  0  0  1     0
> MatGetRow          26874 1.2 9.8243e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatGetRowIJ            1 0.0 2.5988e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering         1 0.0 1.5616e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 5.0e-01  0  0   0  0  0   0  0  0  0  0     0
> MatCoarsen             2 1.0 2.9671e-02 1.0 0.00e+00 0.0 2.4e+01 7.0e+03
> 3.8e+01  0  0  0  0  0   0  0  0  0  0     0
> MatAXPY                2 1.0 6.1393e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00
> MatTranspose           2 1.0 1.8161e-01 1.1 0.00e+00 0.0 3.0e+01 7.1e+03
> 9.4e+01  0  0  0  0  0   0  0  0  0  0     0
> MatMatMult             2 1.0 1.1968e-01 1.0 3.31e+05 1.2 3.6e+01 1.7e+03
> 1.1e+02  0  0  0  0  0   0  0  0  0  0    10
> MatMatMultSym          2 1.0 9.8982e-02 1.0 0.00e+00 0.0 3.0e+01 1.4e+03
> 9.6e+01  0  0  0  0  0   0  0  0  0  0     0
> MatMatMultNum          2 1.0 2.1248e-02 1.1 3.31e+05 1.2 6.0e+00 3.4e+03
> 1.2e+01  0  0  0  0  0   0  0  0  0  0    56
> MatPtAP                2 1.0 1.7070e-01 1.1 2.36e+06 1.2 5.4e+01 3.3e+03
> 1.1e+02  0  0  0  0  0   0  0  0  0  0    50
> MatPtAPSymbolic        2 1.0 1.3786e-01 1.1 0.00e+00 0.0 4.8e+01 3.1e+03
> 1.0 e+02  0  0  0  0  0   0  0  0  0  0     0
> MatPtAPNumeric         2 1.0 4.7638e-02 2.2 2.36e+06 1.2 6.0e+00 4.8e+03
> 1.2e+01  0  0  0  0  0   0  0  0  0  0   180
> MatTrnMatMult          2 1.0 7.9914e-01 1.0 1.14e+07 1.3 3.6e+01 2.1e+04
> 1.2e+02  0  0  0  1  0   0  0  0  1  0    48
> MatGetLocalMat        10 1.0 6.7852e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.4e+01  0  0  0  0  0   0  0  0  0  0     0
> MatGetBrAoCol          6 1.0 3.6962e-02 2.4 0.00e+00 0.0 4.2e+01 4.5e+03
> 1.6e+01  0  0  0  0  0 &nbsp ; 0  0  0  0  0     0
> MatGetSymTrans         4 1.0 4.4394e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> VecMDot              913 1.0 2.8472e+00 3.0 5.28e+08 1.0 0.0e+00 0.0e+00
> 9.1e+02  1 24  0  0  2   1 24  0  0  2   741
> VecNorm             1367 1.0 2.7202e+00 1.6 7.12e+06 1.0 0.0e+00 0.0e+00
> 1.4e+03  1  0  0  0  2   1  0  0  0  2    10
> VecScale            4950 1.0 6.0693e-02 1.2 1.96e+07 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0  1169
> VecCopy             1349 1.0 7.8685e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet              4972 1.0 1.2852e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY             7624 1.0 1.3610e-01 1.1 6.44e+07 1.2 0.0e+00 0.0e+00
> 0.0e+00  0  3  0  0  0   0  3  0  0  0  1676
> VecAYPX             7168 1.0 1.5877e-01 1.2 4.01e+07 1.2 0.0e+00 0.0e+00
> 0.0e+00  0  2  0  0  0 &nbsp ; 0  2  0  0  0   896
> VecMAXPY            1366 1.0 6.3739e-01 1.3 5.35e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 25  0  0  0   0 25  0  0  0  3353
> VecAssemblyBegin      21 1.0 4.7891e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+01  0  0  0  0  0   0  0  0  0  0     0
> VecAssemblyEnd        21 1.0 4.5776e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> VecPointwiseMult    5398 1.0 1.2278e-01 1.3 2.42e+07 1.2 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0   698
> VecScatterBegin     8107 1.0 3.9436 e-02 1.3 0.00e+00 0.0 2.2e+04 3.4e+03
> 0.0e+00  0  0 99 98  0   0  0 99 98  0     0
> VecScatterEnd       8107 1.0 1.5414e+01344.4 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
> VecSetRandom           2 1.0 1.1868e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize        1366 1.0 2.7266e+00 1.6 1.07e+07 1.0 0.0e+00 0.0e+00
> 1.4e+03  1  0  0  0  2   1  0  0  0  2    15
> KSPGMRESOrthog       913 1.0 8.5743e+00 1.1 1.06e+09 1.0 0.0e+00 0.0e+00
> 3.6e+04  3 49  0  0 60 &nb sp; 3 49  0  0 60   492
> KSPSetUp               7 1.0 2.4805e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSolve               1 1.0 5.7656e+01 1.0 2.30e+09 1.1 2.2e+04 3.4e+03
> 6.0e+04 18100100100100  18100100100100   151
> PCSetUp                2 1.0 2.1524e+00 1.0 2.03e+07 1.3 3.8e+02 6.0e+03
> 1.1e+03  1  1  2  3  2   1  1  2  3  2    33
> PCSetUpOnBlocks      448 1.0 1.5607e-03 1.8 1.85e+04 0.0 0.0e+00 0.0e+00
> 8.0e+00  0  0  0  0  0   0  0  0  0  0  & nbsp; 12
> PCApply              448 1.0 4.4331e+01 1.1 1.08e+09 1.2 1.9e+04 3.4e+03
> 2.3e+04 14 44 86 85 38  14 44 86 85 38    87
> PCGAMGgraph_AGG        2 1.0 6.1282e-01 1.0 3.36e+05 1.2 6.6e+01 5.7e+03
> 1.9e+02  0  0  0  0  0   0  0  0  0  0     2
> PCGAMGcoarse_AGG       2 1.0 8.8854e-01 1.0 1.14e+07 1.3 9.0e+01 1.2e+04
> 2.1e+02  0  0  0  1  0   0  0  0  1  0    44
> PCGAMGProl_AGG         2 1.0 6.3711e-02 1.1 0.00e+00 0.0 4.2e+01 2.3e+03
> 1.0e+02  0  0  0  0  0   0  0  0  0  0     0
> PCGAMGPOpt_AGG         2 1.0 3.4247e-01 1.0 6.22e+06 1.2 9.6e+01 2.8e+03
> 3.3e+02  0  0  0  0  1   0  0  0  0  1    65
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Matrix    68             68     27143956     0
>       Matrix Coarsen     2              2          704     0
>               Vector   296            296     13385864     0
>       Vector Scatter    18             18        11304     0
>         & nbsp;  Index Set    47             47        34816     0
>        Krylov Solver     7              7       554688     0
>       Preconditioner     7              7         3896     0
>          PetscRandom     2              2          704     0
>             &nbsp ; Viewer     1              0            0     0
> Average time to get PetscTime(): 1.3113e-06
> Average time for MPI_Barrier(): 9.62257e-05
> Average time for zero size MPI_Send(): 0.00019449
> #PETSc Option Table entries:
> -ksp_converged_reason
> -ksp_gmres_restart 170
> -ksp_rtol 1.0e-15
> -ksp_type gmres
> -log_summary
> -pc_gamg_agg_nsmooths 1
> -pc_type gamg
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure run at: Thu Nov  1 05:54:48 2012
> Configure options: --with-mpi-dir=/home/ub u/soft/mpich2/
> --download-f-blas-lapack =1
> Libraries compiled on Thu Nov  1 05:54:48 2012 on ubuntu
> Machine characteristics:
> Linux-2.6.32-38-generic-i686-with-Ubuntu-10.04-lucid
> Using PETSc directory: /home/ubu/soft/petsc/petsc-3.3-p4
> Using PETSc arch: arch-linux2-c-debug
> Using C compiler: /home/ubu/soft/mpich2/bin/mpicc  -wd1572 -g
> ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler: /home/ubu/soft/mpich2/bin/mpif90  -g
> ${FOPTFLAGS} ${FFLAGS}
> Using include paths:
> -I/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/include
> -I/home/ubu/soft/petsc/petsc-3.3-p4/include
> -I/home/ubu/soft/mpich2/include
> Using C linker: /home/ubu/soft/mpich2/bin/mpicc
> Using Fortran linker: /home/ubu/soft/mpich2/bin/mpif90
> Using libraries:
> -Wl,-rpath,/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib
> -L/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -lpetsc
> -lpthread
> -L/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -lflapack
> -lfblas -L/home/ubu/soft/mpich2/lib
> -L/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32
> -L/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
> -L/opt/intel/composer_xe_2011_sp1.10.319/mkl/lib/ia32
> -L/opt/intel/composer_xe_2011_sp1.10.319/tbb/lib/ia32/cc4.1.0_libc2.4_kernel2.6.16.21
> -L/opt/intel/composer_xe_2011_sp1.9.293/compiler/lib/ia32
> -L/opt/intel/composer_xe_2011_sp1.9.293/mkl/lib/ia32
> -L/usr/lib/gcc/i486-linux-gnu/4.4.3 -L/usr/lib/i486-linux-gnu -lmpichf90
> -lifport -lifcore -lm -lm -ldl -lmpich -lopa -lmpl -lrt -lpthread -limf
> -lsvml -lipgo -ldecimal -lci lkrts -lstdc++ -lgcc_s -lirc -lirc_s -ldl
>  time   14.4289010000000
>  time   14.4289020000000
>  time   14.4449030000000
>  time   14.4809050000000
> (2) using asm
> Linear solve converged due to CONVERGED_RTOL iterations 483
> Norm of error  0.2591E+04 iterations   483
>   4.866092420969481E-018  0.000000000000000E+000  0.000000000000000E+000
>    26.4211453778395      -4.861214483821431E-017  5.379151535696287E-018
> Nov  3 10:00:43 2012
> Time (sec):           2.952e+02      1.00006   2.952e+02
> Objects:              2.040e+02      1.00000   2.040e+02
> Flops:                1.502e+09      1.00731   1.496e+09  5.983e+09
> Flops/sec:            5.088e+06      1.00734   5.067e+06  2.027e+07
> Memory:                2.036e+07      1.01697              8.073e+07
> MPI Messages:         1.960e+03      2.00000   1.470e+03  5.880e+03
> MPI Message Lengths:  7.738e+06      3.12820   3.474e+03  2.042e+07
> MPI Reductions:       4.236e+04      1.00000
> --> 2N flops
> --> 8N flops
>  0:      Main Stage: 2.9517e+02 100.0%  5.9826e+09 100.0%  5.880e+03
> 100.0%  3.474e+03      100.0%  4.236e+04 100.0%
> Phase summary info:
> PetscLogStagePop().
> phase
>   & nbsp;   %M - percent messages in this phase     %L - percent message
> lengths in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>       #                          WARNING!!!                    #
>       #                             & nbsp;                          #
>       #                                &n bsp;                       #
> MatMult              485 1.0 3.1170e+00 5.9 1.36e+08 1.0 2.9e+03 3.4e+03
> 0.0e+00  1  9 49 48  0   1  9 49 48  0   173
> MatSolve             486 1.0 6.8313e-01 1.3 1.49e+08 1.1 0.0e+00 0.0e+00
> 0.0e+00  0 10  0  0  0   0 10  0  0  0   842
> MatLUFactorNum         1 1.0 6.0117e-02 1.2 1.54e+06 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0    99
> MatILUFactorSym        1 1.0 1.5973e-01 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyBegin       2 1 .0 6.0572e-02 9.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd         2 1.0 1.7764e-02 1.6 0.00e+00 0.0 1.2e+01 8.5e+02
> 1.9e+01  0  0  0  0  0   0  0  0  0  0     0
> MatGetRowIJ            1 1.0 3.8147e-06 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetSubMatrice       1 1.0 1.9829e-01 2.1 0.00e+00 0.0 3.0e+01 2.1e+04
> 1.0e+01  0  0  1  3  0   0  0  1  3  0     0
> MatGetOrdering         1 1.0 1.2739e-02 5.8 0.00e+00 0.0 0.0e+00 0 .0e+00
> 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatIncreaseOvrlp       1 1.0 1.8877e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> VecMDot              483 1.0 4.5957e+00 2.5 5.98e+08 1.0 0.0e+00 0.0e+00
> 4.8e+02  1 40  0  0  1   1 40  0  0  1   521
> VecNorm              487 1.0 2.0843e+00 1.2 7.40e+06 1.0 0.0e+00 0.0e+00
> 4.9e+02  1  0  0  0  1   1  0  0  0  1    14
> VecScale             486 1.0 1.2140e-02 1.1 3.69e+06 1.0 0.0e+00 0.0e+00
> 0.0 e+00  0  0  0  0  0   0  0  0  0  0  1217
> VecCopy                3 1.0 4.2915e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet               979 1.0 8.1432e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY                6 1.0 2.3413e-04 1.3 9.12e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1558
> VecMAXPY             486 1.0 7. 0027e-01 1.2 6.06e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 41  0  0  0   0 41  0  0  0  3460
> VecAssemblyBegin       1 1.0 5.7101e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAssemblyEnd         1 1.0 3.0994e-06 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin     1457 1.0 9.1357e-02 2.6 0.00e+00 0.0 5.8e+03 3.4e+03
> 0.0e+00  0  0 99 97  0   0  0 99 97  0     0
> VecScatterEnd       1457 1.0 2.5327e+00323.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0&n bsp; 0     0
> VecNormalize         486 1.0 2.0858e+00 1.2 1.11e+07 1.0 0.0e+00 0.0e+00
> 4.9e+02  1  1  0  0  1   1  1  0  0  1    21
> KSPGMRESOrthog       483 1.0 1.1152e+01 1.2 1.20e+09 1.0 0.0e+00 0.0e+00
> 4.0e+04  3 80  0  0 94   3 80  0  0 94   429
> KSPSetUp               2 1.0 1.1989e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve               1 1.0 2.0990e+01 1.0 1.50e+09 1.0 5.9e+03 3.5e+03
> 4.2e+04  7100100100100   7100100100100   285
> PCSetUp      & nbsp;         2 1.0 3.5928e-01 1.0 1.54e+06 1.1 4.2e+01
> 1.5e+04 3.5e+01  0  0  1  3  0   0  0  1  3  0    17
> PCSetUpOnBlocks        1 1.0 2.2166e-01 1.7 1.54e+06 1.1 0.0e+00 0.0e+00
> 6.0e+00  0  0  0  0  0   0  0  0  0  0    27
> PCApply              486 1.0 5.9831e+00 2.8 1.49e+08 1.1 2.9e+03 3.4e+03
> 1.5e+03  1 10 50 48  3   1 10 50 48  3    96
>               Matrix     5              5      8051336     0
>               Vector   182            182     11109304     0
>       Vector Scatter     2              2         1256     0
>            Index Set    10             10       121444     0
>    & nbsp;   Krylov Solver     2              2       476844     0
>       Preconditioner     2              2         1088     0
>               Viewer     1              0            0     0
> Average time to get PetscTime(): 9.05991e-07
> Average time for MPI_Barrier(): 0.000297785
> Average time for zero size MPI_Send() : 0.000174284
> -ksp_rtol 1.0e-15
> -ksp_type gmres
> -log_summary
> -pc_type asm
> Configure options: --with-mpi-dir=/home/ubu/soft/mpich2/
> Using libraries:
> -lpthread -Wl,-rpath,/home/u
> -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lirc_s -ldl
>  time   5.72435800000000
>  time   5.40433800000000
>  time   5.39233700000000
>  time   5.51634499999999
> >At 2012-11-03 23:53:42,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
> >Just pass it as a command line option. It gives profiling output in
> PetscFinalize().
> >On Sat, Nov 3, 2012 at 10:52 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>  >Is there something that need attention when setting up PETSc? The
>> -log_summary
>> >is no use in my system.
>> >At 2012-11-03 23:31:52,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>> >1. *Always* send -log_summary when asking about performance.
>> >2. AMG setup costs more, the solve should be faster, especially for
>> large problems.
>> >3. 30k degrees of freedom is not large.
>>  >>On Sat, Nov 3, 2012 at 10:27 AM, w_ang_temp <w_ang_temp at 163.com>wrote:
>>>  >>Hello,
>>> >>    I have tried AMG, but there are some problems. I use the command:
>>> >>    mpiexec -n 4 ./ex4f -ksp_type gmres -pc_type gamg
>>> -pc_gamg_agg_nsmooths 1 -ksp_gmres_restart 170 -ksp_rtol 1.0e-15
>>> ->>ksp_converged_reason.
>>> >>    The matrix has a size of 30000. However, compared with -pc_type
>>> asm,
>>> >>the amg need more time:asm needs 4.9s, amg needs 13.7s. I did several
>>> tests
>>> >>and got the same conclusion. When it begins, the screen shows the
>>> information:
>>> >>[0]PCSetData_AGG bs=1 MM=7601. I do not know the meaning. And if there
>>> is some
>>> >>parameters that affect the performance of AMG?
>>> >>    Besides, I want to confirm a conception. In my view, AMG itself
>>> can be a solver
>>> >>like gmres. It can also be used as a preconditioner like jacobi and is
>>> used by combining
>>> >>with other solver. Is it right? If it is right, how use AMG solver?
>>> >>    My codes are attached.
>>> >>    Thanks.
>>> >>                                             Jim
>>> >At 2012-11-01 22:00:28,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>>> >Yes, it's faster to understand this error message than to have
>>> "mysteriously slow performance".
>>> >** Preallocation routines now automatically set
>>> MAT_NEW_NONZERO_ALLOCATION_ERR, if you intentionally preallocate less than
>>> necessary then *>*use
>>> MatSetOption(mat,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE) to disable the
>>> error generation.
>>> >http://www.mcs.anl.gov/petsc/documentation/changes/33.html
>>> >On Thu, Nov 1, 2012 at 8:57 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>>> >Do you mean that the two versions have a different in this point? If I
>>>> use the new version, I have to
>>>> >make some modifications on my codes?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121103/49ef8f87/attachment-0001.html>
