[petsc-users] How to use multigrid?
w_ang_temp w_ang_temp at 163.com
Sat Nov 3 12:17:47 CDT 2012
>At 2012-11-04 01:08:26,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>1. What kind of equation are you solving? AMG is not working well if it takes that many iterations.
I just deal with the typical soil-water coupled geotechnical problems. It is a typical finite element equation. The matrix is 30000X30000 and ill-conditioned.
2.
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
It is true a debugging version. And I used the same version dealing with the same problem, one preconditioner is asm
and the other is amg. The time with amg is about 3 times as with asm. I do not know the reason. And I also do not know the
meaning of '[0]PCSetData_AGG bs=1 MM=7601'.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121104/c23dc296/attachment.html>
