[petsc-users] How to use multigrid?
w_ang_temp w_ang_temp at 163.com
Sat Nov 3 12:05:28 CDT 2012
(1)  using AMG
[0]PCSetData_AGG bs=1 MM=7601
Linear solve converged due to CONVERGED_RTOL iterations 445
Norm of error  0.2591E+04 iterations   445
  0.000000000000000E+000  0.000000000000000E+000  0.000000000000000E+000
 -2.105776715959587E-017  0.000000000000000E+000  0.000000000000000E+000
   26.4211453778391      -3.262172452839194E-017 -2.114490133288630E-017
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./ex4f on a arch-linux2-c-debug named ubuntu with 4 processors, by ubu Sat Nov  3 09:29:28 2012
Using Petsc Release Version 3.3.0, Patch 4, Fri Oct 26 10:46:51 CDT 2012
                         Max       Max/Min        Avg      Total
Time (sec):           3.198e+02      1.00002   3.198e+02
Objects:              4.480e+02      1.00000   4.480e+02
Flops:                2.296e+09      1.08346   2.172e+09  8.689e+09
Flops/sec:            7.181e+06      1.08344   6.792e+06  2.717e+07
Memory:               2.374e+07      1.04179              9.297e+07
MPI Messages:         6.843e+03      1.87582   5.472e+03  2.189e+04
MPI Message Lengths:  2.660e+07      2.08884   3.446e+03  7.542e+07
MPI Reductions:       6.002e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 3.1981e+02 100.0%  8.6886e+09 100.0%  2.189e+04 100.0%  3.446e+03      100.0%  6.001e+04 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult             6291 1.0 2.1431e+01 4.2 1.01e+09 1.2 1.9e+04 3.4e+03 0.0e+00  4 42 86 85  0   4 42 86 85  0   170
MatMultAdd           896 1.0 4.8204e-01 1.1 2.79e+07 1.2 1.3e+03 3.4e+03 0.0e+00  0  1  6  6  0   0  1  6  6  0   208
MatMultTranspose     896 1.0 2.2052e+00 1.3 2.79e+07 1.2 1.3e+03 3.4e+03 1.8e+03  1  1  6  6  3   1  1  6  6  3    45
MatSolve             896 0.0 1.4953e-02 0.0 2.44e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   163
MatLUFactorSym         1 1.0 1.7595e-04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.3995e-0423.5 1.85e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   132
MatConvert             2 1.0 3.1026e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
MatScale               6 1.0 8.9679e-03 5.7 3.98e+05 1.2 6.0e+00 3.4e+03 4.0e+00  0  0  0  0  0   0  0  0  0  0   158
MatAssemblyBegin      37 1.0 2.1544e-01 1.7 0.00e+00 0.0 5.4e+01 6.4e+03 4.2e+01  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        37 1.0 2.5336e-01 1.4 0.00e+00 0.0 9.0e+01 6.8e+02 3.1e+02  0  0  0  0  1   0  0  0  0  1     0
MatGetRow          26874 1.2 9.8243e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 0.0 2.5988e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 0.0 1.5616e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e-01  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             2 1.0 2.9671e-02 1.0 0.00e+00 0.0 2.4e+01 7.0e+03 3.8e+01  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                2 1.0 6.1393e-04 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatTranspose           2 1.0 1.8161e-01 1.1 0.00e+00 0.0 3.0e+01 7.1e+03 9.4e+01  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             2 1.0 1.1968e-01 1.0 3.31e+05 1.2 3.6e+01 1.7e+03 1.1e+02  0  0  0  0  0   0  0  0  0  0    10
MatMatMultSym          2 1.0 9.8982e-02 1.0 0.00e+00 0.0 3.0e+01 1.4e+03 9.6e+01  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum          2 1.0 2.1248e-02 1.1 3.31e+05 1.2 6.0e+00 3.4e+03 1.2e+01  0  0  0  0  0   0  0  0  0  0    56
MatPtAP                2 1.0 1.7070e-01 1.1 2.36e+06 1.2 5.4e+01 3.3e+03 1.1e+02  0  0  0  0  0   0  0  0  0  0    50
MatPtAPSymbolic        2 1.0 1.3786e-01 1.1 0.00e+00 0.0 4.8e+01 3.1e+03 1.0e+02  0  0  0  0  0   0  0  0  0  0     0
MatPtAPNumeric         2 1.0 4.7638e-02 2.2 2.36e+06 1.2 6.0e+00 4.8e+03 1.2e+01  0  0  0  0  0   0  0  0  0  0   180
MatTrnMatMult          2 1.0 7.9914e-01 1.0 1.14e+07 1.3 3.6e+01 2.1e+04 1.2e+02  0  0  0  1  0   0  0  0  1  0    48
MatGetLocalMat        10 1.0 6.7852e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          6 1.0 3.6962e-02 2.4 0.00e+00 0.0 4.2e+01 4.5e+03 1.6e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetSymTrans         4 1.0 4.4394e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot              913 1.0 2.8472e+00 3.0 5.28e+08 1.0 0.0e+00 0.0e+00 9.1e+02  1 24  0  0  2   1 24  0  0  2   741
VecNorm             1367 1.0 2.7202e+00 1.6 7.12e+06 1.0 0.0e+00 0.0e+00 1.4e+03  1  0  0  0  2   1  0  0  0  2    10
VecScale            4950 1.0 6.0693e-02 1.2 1.96e+07 1.1 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1169
VecCopy             1349 1.0 7.8685e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              4972 1.0 1.2852e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             7624 1.0 1.3610e-01 1.1 6.44e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  1676
VecAYPX             7168 1.0 1.5877e-01 1.2 4.01e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   896
VecMAXPY            1366 1.0 6.3739e-01 1.3 5.35e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 25  0  0  0   0 25  0  0  0  3353
VecAssemblyBegin      21 1.0 4.7891e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        21 1.0 4.5776e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult    5398 1.0 1.2278e-01 1.3 2.42e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   698
VecScatterBegin     8107 1.0 3.9436e-02 1.3 0.00e+00 0.0 2.2e+04 3.4e+03 0.0e+00  0  0 99 98  0   0  0 99 98  0     0
VecScatterEnd       8107 1.0 1.5414e+01344.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecSetRandom           2 1.0 1.1868e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize        1366 1.0 2.7266e+00 1.6 1.07e+07 1.0 0.0e+00 0.0e+00 1.4e+03  1  0  0  0  2   1  0  0  0  2    15
KSPGMRESOrthog       913 1.0 8.5743e+00 1.1 1.06e+09 1.0 0.0e+00 0.0e+00 3.6e+04  3 49  0  0 60   3 49  0  0 60   492
KSPSetUp               7 1.0 2.4805e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 5.7656e+01 1.0 2.30e+09 1.1 2.2e+04 3.4e+03 6.0e+04 18100100100100  18100100100100   151
PCSetUp                2 1.0 2.1524e+00 1.0 2.03e+07 1.3 3.8e+02 6.0e+03 1.1e+03  1  1  2  3  2   1  1  2  3  2    33
PCSetUpOnBlocks      448 1.0 1.5607e-03 1.8 1.85e+04 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  0    12
PCApply              448 1.0 4.4331e+01 1.1 1.08e+09 1.2 1.9e+04 3.4e+03 2.3e+04 14 44 86 85 38  14 44 86 85 38    87
PCGAMGgraph_AGG        2 1.0 6.1282e-01 1.0 3.36e+05 1.2 6.6e+01 5.7e+03 1.9e+02  0  0  0  0  0   0  0  0  0  0     2
PCGAMGcoarse_AGG       2 1.0 8.8854e-01 1.0 1.14e+07 1.3 9.0e+01 1.2e+04 2.1e+02  0  0  0  1  0   0  0  0  1  0    44
PCGAMGProl_AGG         2 1.0 6.3711e-02 1.1 0.00e+00 0.0 4.2e+01 2.3e+03 1.0e+02  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         2 1.0 3.4247e-01 1.0 6.22e+06 1.2 9.6e+01 2.8e+03 3.3e+02  0  0  0  0  1   0  0  0  0  1    65
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix    68             68     27143956     0
      Matrix Coarsen     2              2          704     0
              Vector   296            296     13385864     0
      Vector Scatter    18             18        11304     0
           Index Set    47             47        34816     0
       Krylov Solver     7              7       554688     0
      Preconditioner     7              7         3896     0
         PetscRandom     2              2          704     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 1.3113e-06
Average time for MPI_Barrier(): 9.62257e-05
Average time for zero size MPI_Send(): 0.00019449
#PETSc Option Table entries:
-ksp_converged_reason
-ksp_gmres_restart 170
-ksp_rtol 1.0e-15
-ksp_type gmres
-log_summary
-pc_gamg_agg_nsmooths 1
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Thu Nov  1 05:54:48 2012
Configure options: --with-mpi-dir=/home/ubu/soft/mpich2/ --download-f-blas-lapack =1
Libraries compiled on Thu Nov  1 05:54:48 2012 on ubuntu
Machine characteristics: Linux-2.6.32-38-generic-i686-with-Ubuntu-10.04-lucid
Using PETSc directory: /home/ubu/soft/petsc/petsc-3.3-p4
Using PETSc arch: arch-linux2-c-debug
Using C compiler: /home/ubu/soft/mpich2/bin/mpicc  -wd1572 -g  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /home/ubu/soft/mpich2/bin/mpif90  -g   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/include -I/home/ubu/soft/petsc/petsc-3.3-p4/include -I/home/ubu/soft/petsc/petsc-3.3-p4/include -I/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/include -I/home/ubu/soft/mpich2/include
Using C linker: /home/ubu/soft/mpich2/bin/mpicc
Using Fortran linker: /home/ubu/soft/mpich2/bin/mpif90
Using libraries: -Wl,-rpath,/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -L/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -lpetsc -lpthread -Wl,-rpath,/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -L/home/ubu/soft/petsc/petsc-3.3-p4/arch-linux2-c-debug/lib -lflapack -lfblas -L/home/ubu/soft/mpich2/lib -L/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32 -L/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32 -L/opt/intel/composer_xe_2011_sp1.10.319/mkl/lib/ia32 -L/opt/intel/composer_xe_2011_sp1.10.319/tbb/lib/ia32/cc4.1.0_libc2.4_kernel2.6.16.21 -L/opt/intel/composer_xe_2011_sp1.9.293/compiler/lib/ia32 -L/opt/intel/composer_xe_2011_sp1.9.293/mkl/lib/ia32 -L/usr/lib/gcc/i486-linux-gnu/4.4.3 -L/usr/lib/i486-linux-gnu -lmpichf90 -lifport -lifcore -lm -lm -ldl -lmpich -lopa -lmpl -lrt -lpthread -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lirc_s -ldl
 time   14.4289010000000
 time   14.4289020000000
 time   14.4449030000000
 time   14.4809050000000
(2) using asm
Linear solve converged due to CONVERGED_RTOL iterations 483
Norm of error  0.2591E+04 iterations   483
  4.866092420969481E-018  0.000000000000000E+000  0.000000000000000E+000
   26.4211453778395      -4.861214483821431E-017  5.379151535696287E-018
./ex4f on a arch-linux2-c-debug named ubuntu with 4 processors, by ubu Sat Nov  3 10:00:43 2012
Time (sec):           2.952e+02      1.00006   2.952e+02
Objects:              2.040e+02      1.00000   2.040e+02
Flops:                1.502e+09      1.00731   1.496e+09  5.983e+09
Flops/sec:            5.088e+06      1.00734   5.067e+06  2.027e+07
Memory:               2.036e+07      1.01697              8.073e+07
MPI Messages:         1.960e+03      2.00000   1.470e+03  5.880e+03
MPI Message Lengths:  7.738e+06      3.12820   3.474e+03  2.042e+07
MPI Reductions:       4.236e+04      1.00000
 0:      Main Stage: 2.9517e+02 100.0%  5.9826e+09 100.0%  5.880e+03 100.0%  3.474e+03      100.0%  4.236e+04 100.0%
Phase summary info:
      #                          WARNING!!!                    #
MatMult              485 1.0 3.1170e+00 5.9 1.36e+08 1.0 2.9e+03 3.4e+03 0.0e+00  1  9 49 48  0   1  9 49 48  0   173
MatSolve             486 1.0 6.8313e-01 1.3 1.49e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 10  0  0  0   0 10  0  0  0   842
MatLUFactorNum         1 1.0 6.0117e-02 1.2 1.54e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    99
MatILUFactorSym        1 1.0 1.5973e-01 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       2 1.0 6.0572e-02 9.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         2 1.0 1.7764e-02 1.6 0.00e+00 0.0 1.2e+01 8.5e+02 1.9e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 3.8147e-06 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       1 1.0 1.9829e-01 2.1 0.00e+00 0.0 3.0e+01 2.1e+04 1.0e+01  0  0  1  3  0   0  0  1  3  0     0
MatGetOrdering         1 1.0 1.2739e-02 5.8 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatIncreaseOvrlp       1 1.0 1.8877e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMDot              483 1.0 4.5957e+00 2.5 5.98e+08 1.0 0.0e+00 0.0e+00 4.8e+02  1 40  0  0  1   1 40  0  0  1   521
VecNorm              487 1.0 2.0843e+00 1.2 7.40e+06 1.0 0.0e+00 0.0e+00 4.9e+02  1  0  0  0  1   1  0  0  0  1    14
VecScale             486 1.0 1.2140e-02 1.1 3.69e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1217
VecCopy                3 1.0 4.2915e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               979 1.0 8.1432e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                6 1.0 2.3413e-04 1.3 9.12e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1558
VecMAXPY             486 1.0 7.0027e-01 1.2 6.06e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 41  0  0  0   0 41  0  0  0  3460
VecAssemblyBegin       1 1.0 5.7101e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 3.0994e-06 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     1457 1.0 9.1357e-02 2.6 0.00e+00 0.0 5.8e+03 3.4e+03 0.0e+00  0  0 99 97  0   0  0 99 97  0     0
VecScatterEnd       1457 1.0 2.5327e+00323.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         486 1.0 2.0858e+00 1.2 1.11e+07 1.0 0.0e+00 0.0e+00 4.9e+02  1  1  0  0  1   1  1  0  0  1    21
KSPGMRESOrthog       483 1.0 1.1152e+01 1.2 1.20e+09 1.0 0.0e+00 0.0e+00 4.0e+04  3 80  0  0 94   3 80  0  0 94   429
KSPSetUp               2 1.0 1.1989e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.0990e+01 1.0 1.50e+09 1.0 5.9e+03 3.5e+03 4.2e+04  7100100100100   7100100100100   285
PCSetUp                2 1.0 3.5928e-01 1.0 1.54e+06 1.1 4.2e+01 1.5e+04 3.5e+01  0  0  1  3  0   0  0  1  3  0    17
PCSetUpOnBlocks        1 1.0 2.2166e-01 1.7 1.54e+06 1.1 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0    27
PCApply              486 1.0 5.9831e+00 2.8 1.49e+08 1.1 2.9e+03 3.4e+03 1.5e+03  1 10 50 48  3   1 10 50 48  3    96
              Matrix     5              5      8051336     0
              Vector   182            182     11109304     0
      Vector Scatter     2              2         1256     0
           Index Set    10             10       121444     0
       Krylov Solver     2              2       476844     0
      Preconditioner     2              2         1088     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 9.05991e-07
Average time for MPI_Barrier(): 0.000297785
Average time for zero size MPI_Send(): 0.000174284
-ksp_rtol 1.0e-15
-ksp_type gmres
-log_summary
-pc_type asm
 time   5.72435800000000
 time   5.40433800000000
 time   5.39233700000000
 time   5.51634499999999
>At 2012-11-03 23:53:42,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>Just pass it as a command line option. It gives profiling output in PetscFinalize().
>On Sat, Nov 3, 2012 at 10:52 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>Is there something that need attention when setting up PETSc? The -log_summary
>is no use in my system.
>At 2012-11-03 23:31:52,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>1. Always send -log_summary when asking about performance.
>2. AMG setup costs more, the solve should be faster, especially for large problems.
>3. 30k degrees of freedom is not large.
>>On Sat, Nov 3, 2012 at 10:27 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>Hello,
>>    I have tried AMG, but there are some problems. I use the command:
>>    mpiexec -n 4 ./ex4f -ksp_type gmres -pc_type gamg -pc_gamg_agg_nsmooths 1 -ksp_gmres_restart 170 -ksp_rtol 1.0e-15 ->>ksp_converged_reason.
>>    The matrix has a size of 30000. However, compared with -pc_type asm,
>>the amg need more time:asm needs 4.9s, amg needs 13.7s. I did several tests
>>and got the same conclusion. When it begins, the screen shows the information:
>>[0]PCSetData_AGG bs=1 MM=7601. I do not know the meaning. And if there is some
>>parameters that affect the performance of AMG?
>>    Besides, I want to confirm a conception. In my view, AMG itself can be a solver
>>like gmres. It can also be used as a preconditioner like jacobi and is used by combining
>>with other solver. Is it right? If it is right, how use AMG solver?
>>    My codes are attached.
>>    Thanks.
>>                                             Jim
>At 2012-11-01 22:00:28,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>Yes, it's faster to understand this error message than to have "mysteriously slow performance".
>* Preallocation routines now automatically set MAT_NEW_NONZERO_ALLOCATION_ERR, if you intentionally preallocate less than necessary then >use MatSetOption(mat,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE) to disable the error generation.
>http://www.mcs.anl.gov/petsc/documentation/changes/33.html
>On Thu, Nov 1, 2012 at 8:57 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>Do you mean that the two versions have a different in this point? If I use the new version, I have to
>make some modifications on my codes?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121104/565de2c7/attachment-0001.html>
