[petsc-users] Avoiding malloc overhead for unstructured finite element meshes
Thomas DE-SOZA thomas.de-soza at edf.fr
Thu Jun 28 08:59:21 CDT 2012
Dear PETSc Users,
We're experiencing performances issues after having switched to fully
distributed meshes in our in-house code and would like your opinion on the
matter.
In the current version of our structural mechanics FEA software
(http://www.code-aster.org/), all MPI processes have knowledge of the
whole matrix and therefore can easily pass it to PETSc without the need
for any communication. In a nutshell, stash is empty after MatSetValues
and no mallocs occur during assembly.
We're now building a distributed version of the software with each process
reading its own subdomain in order to save memory. The mesh was
partitioned with Metis and as a first approach we built a simple partition
of the degrees of freedom based on the gradual subdomains. This eliminates
the need for Application Ordering but yields an unbalanced decomposition
in terms of rows. If we take an example with 2 MPI processes : processor 0
will have more unknowns than processor 1 and will receive entries lying on
the interface whereas processor 1 will have all entries locally.
PETSc manual states that "It is fine to generate some entries on the
"wrong" process. Often this can lead to cleaner, simpler, less buggy
codes. One should never make code overly complicated in order to generate
all values locally. Rather, one should organize the code in such a way
that most values are generated locally."
Judging from the performance we obtain on a simple cube with two
processes, it seems we have generated too much entries on the wrong
process. Indeed our distributed code runs slower than the current one.
However the stash does not seem to contain that much (650 000 over a total
of 50 000 000 nnz). We have attached the output obtained with "-info" as
well as the "-log_summary" profiling. Most of the time is spent in the
assembly and a lot of mallocs occur.
What's your advice on this ? Is working with ghost cells the only option ?
We were wondering if we could preallocate the stash for example to
decrease the number of mallocs.
Thomas
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120628/03d50847/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120628/03d50847/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120628/03d50847/attachment-0003.obj>
