[petsc-users] Avoiding malloc overhead for unstructured finite element meshes
Tabrez Ali stali at geology.wisc.edu
Thu Jun 28 10:16:59 CDT 2012
Did you renumber your on-rank nodes after partitioning?
T
On 06/28/2012 08:59 AM, Thomas DE-SOZA wrote:
> Dear PETSc Users,
> We're experiencing performances issues after having switched to fully
> distributed meshes in our in-house code and would like your opinion on
> the matter.
> In the current version of our structural mechanics FEA software
> (http://www.code-aster.org/), all MPI processes have knowledge of the
> whole matrix and therefore can easily pass it to PETSc without the
> need for any communication. In a nutshell, stash is empty after
> MatSetValues and no mallocs occur during assembly.
> We're now building a distributed version of the software with each
> process reading its own subdomain in order to save memory. The mesh
> was partitioned with Metis and as a first approach we built a simple
> partition of the degrees of freedom based on the gradual subdomains.
> This eliminates the need for Application Ordering but yields an
> unbalanced decomposition in terms of rows. If we take an example with
> 2 MPI processes : processor 0 will have more unknowns than processor 1
> and will receive entries lying on the interface whereas processor 1
> will have all entries locally.
> PETSc manual states that "It is fine to generate some entries on the
> "wrong" process. Often this can lead to cleaner, simpler, less buggy
> codes. One should never make code overly complicated in order to
> generate all values locally. Rather, one should organize the code in
> such a way that most values are generated locally."
> Judging from the performance we obtain on a simple cube with two
> processes, it seems we have generated too much entries on the wrong
> process. Indeed our distributed code runs slower than the current one.
> However the stash does not seem to contain that much (650 000 over a
> total of 50 000 000 nnz). We have attached the output obtained with
> "-info" as well as the "-log_summary" profiling. Most of the time is
> spent in the assembly and a lot of mallocs occur.
> What's your advice on this ? Is working with ghost cells the only
> option ?
> We were wondering if we could preallocate the stash for example to
> decrease the number of mallocs.
> Regards,
> Thomas
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont
> établis à l'intention exclusive des destinataires et les informations
> qui y figurent sont strictement confidentielles. Toute utilisation de
> ce Message non conforme à sa destination, toute diffusion ou toute
> publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit
> de le copier, de le faire suivre, de le divulguer ou d'en utiliser
> tout ou partie. Si vous avez reçu ce Message par erreur, merci de le
> supprimer de votre système, ainsi que toutes ses copies, et de n'en
> garder aucune trace sur quelque support que ce soit. Nous vous
> remercions également d'en avertir immédiatement l'expéditeur par
> retour du message.
> Il est impossible de garantir que les communications par messagerie
> électronique arrivent en temps utile, sont sécurisées ou dénuées de
> toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely
> for the addressees. The information contained in this Message is
> confidential. Any use of information contained in this Message not in
> accord with its purpose, any dissemination or disclosure, either whole
> or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or
> use any part of it. If you have received this message in error, please
> delete it and all copies from your system and notify the sender
> immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error
> or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120628/8ba01ccd/attachment.html>
