[petsc-users] Ambiguity of KSPCGNE
Alexander Grayver agrayver at gfz-potsdam.de
Wed Jun 20 10:43:38 CDT 2012
Hello,
I'm a bit confused about the KSPCGNE. First of all, is CGLS^1 and
implemented CGNE are the same (or I mix it up with CGNR)? I don't know
what notation is more classical, but CGLS seems to be more common.
It is claimed:
*/Applies the preconditioned conjugate gradient method to the normal
equations without explicitly forming A^t*A /*
Does that mean I have to provide A to KSP? In this case the application
of the method is quite restricted since all practical least squares
problems formulated in form of normal equations are solved with
regularization, e.g.:
(A'A + \lamba I)x = A'b
Assume I have A computed and use matrix free approach to represent (A'A
+ \lamba I) without ever forming it, so what should I do then to apply
KSPCGNE?
Thanks.
1. Bjorck, A., 1996. Numerical Methods for Least Squares Problems, p. 288
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120620/6c51d456/attachment.html>
