[petsc-users] Ambiguity of KSPCGNE
Thu Jun 21 17:32:48 CDT 2012
On Jun 20, 2012, at 10:43 AM, Alexander Grayver wrote:
> Hello,
> I'm a bit confused about the KSPCGNE. First of all, is CGLS^1 and implemented CGNE are the same (or I mix it up with CGNR)? I don't know what notation is more classical, but CGLS seems to be more common.
> It is claimed:
It is the same as this:  http://www.stanford.edu/group/SOL/software/cgls.html
> Applies the preconditioned conjugate gradient method to the normal equations without explicitly forming A^t*A
> Does that mean I have to provide A to KSP?
    Yes you provide A.
> In this case the application of the method is quite restricted since all practical least squares problems formulated in form of normal equations are solved with regularization, e.g.:
> (A'A + \lamba I)x = A'b
Yes it is restrictive. There is no concept of lambda in CGNE in PETSc
> Assume I have A computed and use matrix free approach to represent (A'A + \lamba I) without ever forming it, so what should I do then to apply KSPCGNE?
   If you supply a shell matrix that applies (A'A + \lamba I)  why not just use KSPCG?
    But if you provide this shell matrix, how do you plan to apply a preconditioner?
   Barry
> Thanks.
> 1. Bjorck, A., 1996. Numerical Methods for Least Squares Problems, p. 288
> Regards,
> Alexander
