[petsc-users] PCKSP
Tue Jun 19 13:16:45 CDT 2012
On Tue, Jun 19, 2012 at 12:13 PM, Margarita Satraki <
margarita.satraki at gmail.com> wrote:
> For my problem (incompressible nonlinear elasticity) pcksp seemed to work
> ok with gmres and even better with fgmres.
> The best option was to use LU as PC but this requires a lot of memory.
You can just use
  -ksp_type preonly
  -pc_type lu
to get a direct solution. Its not clear why you would want PCKSP.
> Why do you think that would not be a good option?
Incompressible elasticity has a constraint, so it is a saddle point system.
We would recommend using
PC_FIELDSPLIT, splitting into blocks for the displacement and pressure. You
can do this automatically
using -pc_fieldsplit_detect_saddle_point.
We would also proba bly recommend using AMG (ML, or GAMG, etc.) for the
elastic block. You have to provide
the near null modes (6 rot+trans), but there are examples of this from Mark
Adams and me.
    Matt
> Margarita
> On 19 June 2012 19:00, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Jun 19, 2012 at 11:54 AM, Margarita Satraki <
>>> Thank you very much Matt.
>> I will just point out that this is unlikely to ever be what you want. Do
>> you have a particular solver
>> configuration in mind?
>>     Matt
>>> Margarita
>>> On 19 June 2012 18:44, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Tue, Jun 19, 2012 at 11:41 AM, Margarita Satraki <
>>>>> If I understand correctly:
>>>>> For a system:
>>>>> M^{-1} A x = M^{-1} b
>>>>> we don't need to multiply M^{-1} A explicitly, but we solve M w = v
>>>>> whenever needed.
>>>>> So the Krylov method is used in order to solve that system, or
>>>>> equivalently to compute the vector M^{-1} v?
>>>> Yes
>>>>    Matt
>>>>> On 19 June 2012 17:54, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Tue, Jun 19, 2012 at 10:33 AM, Margarita Satraki <
>>>>>>> Hello,
>>>>>>> I have difficulty understanding how PCKSP works.
>>>>>>> From:
>>>>>>> http://www.mcs.anl.gov/petsc/documentation/tutorials/Columbia04/DDandMultigrid.pdf
>>>>>>> I understand that instead of using preconditioners, it uses Krylov
>>>>>>> methods for the ''inner solvers''.
>>>>>>> What are the ''inner solvers''? Is there some kind of a subsystem
>>>>>>> that is solved instead of applying a preconditioner?
>>>>>> Nope, its jsut like a PC:
>>>>>> where now M^{-1} instead of being an LU solve, for instance, is a
>>>>>> Krylov solve.
>>>>>>    Matt
>>>>>>> Many thanks,
>>>>>>> Margarita
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120619/04a53e8b/attachment.html>
