[petsc-users] PCKSP
Margarita Satraki margarita.satraki at gmail.com
Tue Jun 19 13:38:44 CDT 2012
I'll give it a go. Thanks!
Margarita
On 19 June 2012 19:16, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 19, 2012 at 12:13 PM, Margarita Satraki <
> margarita.satraki at gmail.com> wrote:
>> For my problem (incompressible nonlinear elasticity) pcksp seemed to work
>> ok with gmres and even better with fgmres.
>> The best option was to use LU as PC but this requires a lot of memory.
> You can just use
>   -ksp_type preonly
>   -pc_type lu
> to get a direct solution. Its not clear why you would want PCKSP.
>> Why do you think that would not be a good option?
> Incompressible elasticity has a constraint, so it is a saddle point
> system. We would recommend using
> PC_FIELDSPLIT, splitting into blocks for the displacement and pressure.
> You can do this automatically
> using -pc_fieldsplit_detect_saddle_point.
> We would also proba bly recommend using AMG (ML, or GAMG, etc.) for the
> elastic block. You have to provide
> the near null modes (6 rot+trans), but there are examples of this from
> Mark Adams and me.
>     Matt
>> Margarita
>> On 19 June 2012 19:00, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Jun 19, 2012 at 11:54 AM, Margarita Satraki <
>>>> Thank you very much Matt.
>>> I will just point out that this is unlikely to ever be what you want. Do
>>> you have a particular solver
>>> configuration in mind?
>>>     Matt
>>>> Margarita
>>>> On 19 June 2012 18:44, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Tue, Jun 19, 2012 at 11:41 AM, Margarita Satraki <
>>>>>> If I understand correctly:
>>>>>> For a system:
>>>>>> M^{-1} A x = M^{-1} b
>>>>>> we don't need to multiply M^{-1} A explicitly, but we solve M w = v
>>>>>> whenever needed.
>>>>>> So the Krylov method is used in order to solve that system, or
>>>>>> equivalently to compute the vector M^{-1} v?
>>>>> Yes
>>>>>    Matt
>>>>>> On 19 June 2012 17:54, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>> On Tue, Jun 19, 2012 at 10:33 AM, Margarita Satraki <
>>>>>>>> Hello,
>>>>>>>> I have difficulty understanding how PCKSP works.
>>>>>>>> From:
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/tutorials/Columbia04/DDandMultigrid.pdf
>>>>>>>> I understand that instead of using preconditioners, it uses Krylov
>>>>>>>> methods for the ''inner solvers''.
>>>>>>>> What are the ''inner solvers''? Is there some kind of a subsystem
>>>>>>>> that is solved instead of applying a preconditioner?
>>>>>>> Nope, its jsut like a PC:
>>>>>>> where now M^{-1} instead of being an LU solve, for instance, is a
>>>>>>> Krylov solve.
>>>>>>>    Matt
>>>>>>>> Many thanks,
>>>>>>>> Margarita
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120619/b9f4aa1e/attachment-0001.html>
