[petsc-users] PCKSP
Margarita Satraki margarita.satraki at gmail.com
Tue Jun 19 13:13:11 CDT 2012
For my problem (incompressible nonlinear elasticity) pcksp seemed to work
ok with gmres and even better with fgmres.
The best option was to use LU as PC but this requires a lot of memory.
Why do you think that would not be a good option?
Margarita
On 19 June 2012 19:00, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 19, 2012 at 11:54 AM, Margarita Satraki <
> margarita.satraki at gmail.com> wrote:
>> Thank you very much Matt.
> I will just point out that this is unlikely to ever be what you want. Do
> you have a particular solver
> configuration in mind?
>    Matt
>> Margarita
>> On 19 June 2012 18:44, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Jun 19, 2012 at 11:41 AM, Margarita Satraki <
>>>> If I understand correctly:
>>>> For a system:
>>>> M^{-1} A x = M^{-1} b
>>>> we don't need to multiply M^{-1} A explicitly, but we solve M w = v
>>>> whenever needed.
>>>> So the Krylov method is used in order to solve that system, or
>>>> equivalently to compute the vector M^{-1} v?
>>> Yes
>>>    Matt
>>>> On 19 June 2012 17:54, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Tue, Jun 19, 2012 at 10:33 AM, Margarita Satraki <
>>>>>> Hello,
>>>>>> I have difficulty understanding how PCKSP works.
>>>>>> From:
>>>>>> http://www.mcs.anl.gov/petsc/documentation/tutorials/Columbia04/DDandMultigrid.pdf
>>>>>> I understand that instead of using preconditioners, it uses Krylov
>>>>>> methods for the ''inner solvers''.
>>>>>> What are the ''inner solvers''? Is there some kind of a subsystem
>>>>>> that is solved instead of applying a preconditioner?
>>>>> Nope, its jsut like a PC:
>>>>> where now M^{-1} instead of being an LU solve, for instance, is a
>>>>> Krylov solve.
>>>>>    Matt
>>>>>> Many thanks,
>>>>>> Margarita
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120619/cb349713/attachment.html>
