[petsc-users] MatSetOption bug?
Tue Jun 19 11:49:35 CDT 2012
On Tue, Jun 19, 2012 at 10:06 AM, Anton Popov <popov at uni-mainz.de> wrote:
> Hi petsc team!
> I've recently upgraded to 3.3, and currently experience problems. One of
> them follows.
> If I compile this simple code:
In 3.3, we now require that MatSetUp() is called before messing with the
storage scheme.
We should have been more specific in Changes. Moreover, this should be a
better error
message. Will fix, and see below.
> #include "petsc.h"
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main( int argc,char **argv )
>    Mat A;
>    PetscErrorCode ierr;
>    PetscInt n_rows_Local=100;
>    PetscInt n_cols_Local=100;
>    ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);
> CHKERRQ(ierr);
>    ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
>    ierr = MatSetSizes(A, n_rows_Local, n_cols_Local, PETSC_DETERMINE,
> PETSC_DETERMINE); CHKERRQ(ierr);
>    ierr = MatSetType(A, MATAIJ); CHKERRQ(ierr);
ierr = MatSetUp(A);CHKERRQ(ierr);
    Matt
>    ierr = MatSetOption(A, MAT_KEEP_NONZERO_PATTERN, PETSC_TRUE);
> CHKERRQ(ierr);
>    ierr = PetscFinalize(); CHKERRQ(ierr);
>    PetscFunctionReturn(0);
> and run it in parallel (mpiexec -np 2 ./example) it gives me errors like
> this:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> [0]PETSC ERROR: ------------------------------**
> Commenting the line with "MatSetOption" removes the error, but doesn't
> solve the problem, because I actually need to KEEP_NONZERO_PATTERN
> Running the code sequentially, also vanishes the error.
> Please check whether it's a bug in petsc-3.3, or I should set this option
> in a different way.
> Thanks,
> Anton Popov
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120619/3526e215/attachment.html>
