[petsc-users] MatSetOption bug?
Anton Popov popov at uni-mainz.de
Tue Jun 19 11:06:52 CDT 2012
Hi petsc team!
I've recently upgraded to 3.3, and currently experience problems. One of
them follows.
If I compile this simple code:
#include "petsc.h"
#undef __FUNCT__
#define __FUNCT__ "main"
int main( int argc,char **argv )
     Mat A;
     PetscErrorCode ierr;
     PetscInt n_rows_Local=100;
     PetscInt n_cols_Local=100;
     ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);
CHKERRQ(ierr);
     ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
     ierr = MatSetSizes(A, n_rows_Local, n_cols_Local, PETSC_DETERMINE,
PETSC_DETERMINE); CHKERRQ(ierr);
     ierr = MatSetType(A, MATAIJ); CHKERRQ(ierr);
     ierr = MatSetOption(A, MAT_KEEP_NONZERO_PATTERN, PETSC_TRUE);
CHKERRQ(ierr);
     ierr = PetscFinalize(); CHKERRQ(ierr);
     PetscFunctionReturn(0);
and run it in parallel (mpiexec -np 2 ./example) it gives me errors like
this:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Object: Parameter # 1!
[0]PETSC ERROR:
Commenting the line with "MatSetOption" removes the error, but doesn't
solve the problem, because I actually need to KEEP_NONZERO_PATTERN
Running the code sequentially, also vanishes the error.
Please check whether it's a bug in petsc-3.3, or I should set this
option in a different way.
Anton Popov
