[petsc-users] MatSetOption bug?
Anton Popov popov at uni-mainz.de
Wed Jun 20 04:05:04 CDT 2012
Thanks Matt, it's clear now
On 6/19/12 6:49 PM, Matthew Knepley wrote:
> On Tue, Jun 19, 2012 at 10:06 AM, Anton Popov <popov at uni-mainz.de
> <mailto:popov at uni-mainz.de>> wrote:
>     Hi petsc team!
>     I've recently upgraded to 3.3, and currently experience problems.
>     One of them follows.
>     If I compile this simple code:
> In 3.3, we now require that MatSetUp() is called before messing with
> the storage scheme.
> We should have been more specific in Changes. Moreover, this should be
> a better error
> message. Will fix, and see below.
>     #include "petsc.h"
>     #undef __FUNCT__
>     #define __FUNCT__ "main"
>     int main( int argc,char **argv )
>        Mat A;
>        PetscErrorCode ierr;
>        PetscInt n_rows_Local=100;
>        PetscInt n_cols_Local=100;
>        ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);
>     CHKERRQ(ierr);
>        ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
>        ierr = MatSetSizes(A, n_rows_Local, n_cols_Local,
>     PETSC_DETERMINE, PETSC_DETERMINE); CHKERRQ(ierr);
>        ierr = MatSetType(A, MATAIJ); CHKERRQ(ierr);
> ierr = MatSetUp(A);CHKERRQ(ierr);
>     Matt
>        ierr = MatSetOption(A, MAT_KEEP_NONZERO_PATTERN, PETSC_TRUE);
>     CHKERRQ(ierr);
>        ierr = PetscFinalize(); CHKERRQ(ierr);
>        PetscFunctionReturn(0);
>     and run it in parallel (mpiexec -np 2 ./example) it gives me
>     errors like this:
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Null argument, when expecting valid pointer!
>     [0]PETSC ERROR: Null Object: Parameter # 1!
>     [0]PETSC ERROR:
>     Commenting the line with "MatSetOption" removes the error, but
>     doesn't solve the problem, because I actually need to
>     Running the code sequentially, also vanishes the error.
>     Please check whether it's a bug in petsc-3.3, or I should set this
>     option in a different way.
>     Thanks,
>     Anton Popov
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120620/451dc046/attachment-0001.html>
