[petsc-users] matload big matrix
Sat Jun 2 10:55:50 CDT 2012
   What version of PETSc is this? How was the file generated?  How many processes are you using? Does it work on less processes (like 1, 2 )?  How many nonzeros in the matrix (roughly)?
   Barry
> Hi,
> I am trying to load a big matrix(size 552147 by 552147) from a binary file(around 2GB). But I found my code seems to get stuck at the loading stage. I copied the last a few info output below
> [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374780
> [0] PetscFileRetrieve(): Found file l2projphim.dat
> [0] PetscFileRetrieve(): Found file l2projphim.dat.info
> [0] PetscOptionsInsertFile(): Opened options file l2projphim.dat.info
> Do you have any suggestions? Thanks.
> Regards,
> Wen
