[petsc-users] matload big matrix
Sat Jun 2 10:53:47 CDT 2012
How long is it taking? What file system are you reading the matrix from?
You can attach a debugger and see where it's "stuck".
On Sat, Jun 2, 2012 at 10:47 AM, Wen Jiang <jiangwen84 at gmail.com> wrote:
> Hi,
> I am trying to load a big matrix(size 552147 by 552147) from a binary
> file(around 2GB). But I found my code seems to get stuck at the loading
> stage. I copied the last a few info output below
> [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> -2080374780
> [0] PetscFileRetrieve(): Found file l2projphim.dat
> [0] PetscFileRetrieve(): Found file l2projphim.dat.info
> [0] PetscOptionsInsertFile(): Opened options file l2projphim.dat.info
> Do you have any suggestions? Thanks.
> Regards,
> Wen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120602/cea5726e/attachment.html>
