[petsc-users] [petsc-maint #103068] problems compiling
Fri Jan 20 13:13:04 CST 2012
On Fri, 20 Jan 2012, Dominik Szczerba wrote:
> On Fri, Jan 20, 2012 at 7:56 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> > 2) Dominik, I have pushed a possible fix for this to petsc-dev. Can you try
> >> > running with that on this machine?
> >> There is no mercurial on the system. Is your fix already in the tarball?
> > you can download the patch from here - and apply as before with the patch
> > command. [Note: get the 'raw' patch]
> Please explain the 'raw' part.
http://petsc.cs.iit.edu/petsc/BuildSystem/rev/39eccbe256d3
shows the patch in html. However there is a link on this page with the
text 'raw'
If you click on that - you get plain text patch - that can be applied
with 'patch command'
http://petsc.cs.iit.edu/petsc/BuildSystem/raw-rev/39eccbe256d3
Ig uess I should have just sent the 'raw' link - but figured the html
link had more utility [as its more browsable] - so listed the html
link to the patch.
You can browse all petsc-dev changes at:
http://petsc.cs.iit.edu/petsc/petsc-dev/
Satish
