[petsc-users] [petsc-maint #103068] problems compiling
Dominik Szczerba dominik at itis.ethz.ch
Fri Jan 20 13:03:08 CST 2012
On Fri, Jan 20, 2012 at 7:56 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 20 Jan 2012, Dominik Szczerba wrote:
>> > 2) Dominik, I have pushed a possible fix for this to petsc-dev. Can you try
>> > running with that on this machine?
>> There is no mercurial on the system. Is your fix already in the tarball?
> you can download the patch from here - and apply as before with the patch
> command. [Note: get the 'raw' patch]
Please explain the 'raw' part.
Thanks
