[petsc-users] [petsc-maint #103068] problems compiling
Fri Jan 20 13:57:42 CST 2012
  Please move this thread off of petsc-users and to petsc-maint at mcs.anl.gov
    Barry
On Jan 20, 2012, at 1:13 PM, Satish Balay wrote:
> On Fri, 20 Jan 2012, Dominik Szczerba wrote:
>> On Fri, Jan 20, 2012 at 7:56 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> 2) Dominik, I have pushed a possible fix for this to petsc-dev. Can you try
>>>>> running with that on this machine?
>>>> There is no mercurial on the system. Is your fix already in the tarball?
>>> you can download the patch from here - and apply as before with the patch
>>> command. [Note: get the 'raw' patch]
>> Please explain the 'raw' part.
> http://petsc.cs.iit.edu/petsc/BuildSystem/rev/39eccbe256d3
> shows the patch in html. However there is a link on this page with the
> text 'raw'
> If you click on that - you get plain text patch - that can be applied
> with 'patch command'
> http://petsc.cs.iit.edu/petsc/BuildSystem/raw-rev/39eccbe256d3
> Ig uess I should have just sent the 'raw' link - but figured the html
> link had more utility [as its more browsable] - so listed the html
> link to the patch.
> You can browse all petsc-dev changes at:
> http://petsc.cs.iit.edu/petsc/petsc-dev/
> Satish
