[petsc-users] [petsc-maint #103068] problems compiling
Fri Jan 20 12:56:49 CST 2012
On Fri, 20 Jan 2012, Dominik Szczerba wrote:
> > 2) Dominik, I have pushed a possible fix for this to petsc-dev. Can you try
> > running with that on this machine?
> There is no mercurial on the system. Is your fix already in the tarball?
you can download the patch from here - and apply as before with the patch
command. [Note: get the 'raw' patch]
http://petsc.cs.iit.edu/petsc/BuildSystem/rev/39eccbe256d3
satish
