[petsc-users] Software for load balancing to improve parallel performance to be used with PETSc
Tue Jan 3 18:11:09 CST 2012
On Jan 3, 2012, at 6:03 PM, Jed Brown wrote:
> On Tue, Jan 3, 2012 at 17:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Huh? Since it is a structured cartesian mesh code you just want to split up the z direction so that each process has an equal number of grid points
> I may have misunderstood this: "Uneven grids are used to reduce the number of grids and the main bulk of grids clusters around the center."
   I interpreted this to mean that it is using a graded mesh in certain (or all) coordinate directions. I could be wrong.
   Barry
> If the grid is structured, then I agree to just use a good structured decomposition.
