[petsc-users] Software for load balancing to improve parallel performance to be used with PETSc
Tue Jan 3 18:03:45 CST 2012
On Tue, Jan 3, 2012 at 17:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Huh? Since it is a structured cartesian mesh code you just want to split
> up the z direction so that each process has an equal number of grid points
I may have misunderstood this: "Uneven grids are used to reduce the number
of grids and the main bulk of grids clusters around the center."
If the grid is structured, then I agree to just use a good structured
decomposition.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120103/cb427cda/attachment.htm>
