[petsc-users] Using superlu_dist in a direct solve
Hong Zhang hzhang at mcs.anl.gov
Wed Dec 26 15:34:38 CST 2012
Sanjay:
> hmmm....I guess that is good news -- in that superlu is not broken. However,
> for me
> not so good news since I seems that there is nasty bug lurking on my
> machine.
> Any suggestions on chasing down the error?
How did you install your supelu_dist with petsc-3.3?
What machine do you use?
Hong
> On 12/26/12 1:23 PM, Hong Zhang wrote:
>> Sanjay:
>> I get
>> petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2
>> -ksp_monitor_short  -ksp_type preonly -pc_type lu
>> -pc_factor_mat_solver_package superlu_dist -m 500 -n 500
>> Norm of error 1.92279e-11 iterations 1
>> Hong
>>> I have done some more testing of the problem, continuing with
>>> src/ksp/ksp/examples/tutorials/ex2.c.
>>> The behavior I am seeing is that with smaller problems sizes superlu_dist
>>> is
>>> behaving properly
>>> but with larger problem sizes things seem to go wrong and what goes wrong
>>> is
>>> apparently consistent; the error appears both with my intel build as well
>>> as
>>> with my gcc build.
>>> I have two run lines:
>>> runex2superlu:
>>>          -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 100 -n 100
>>> -ksp_type
>>> preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist
>>> runex2spooles:
>>> -ksp_type
>>> preonly -pc_type lu -pc_factor_mat_solver_package spooles
>>>  From my intel build, I get
>>> sg-macbook-prolocal:tutorials sg$ make runex2superlu
>>> Norm of error 7.66145e-13 iterations 1
>>> sg-macbook-prolocal:tutorials sg$ make runex2spooles
>>> Norm of error 2.21422e-12 iterations 1
>>>  From my GCC build, I get
>>> If I change the -m 100 -n 100 to -m 500 -n 500, I get for my intel build
>>> Norm of error 419.953 iterations 1
>>> Norm of error 2.69468e-10 iterations 1
>>>  From my GCC build with -m 500 -n 500, I get
>>> Any suggestions will be greatly appreciated.
>>> -sanjay
>>> On 12/23/12 6:42 PM, Matthew Knepley wrote:
>>> On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>> wrote:
>>>> I decided to go with ksp/ksp/exampeles/tutorials/ex2.c; I was unsure how
>>>> to convert the run lines for snes/examples/ex5.c to work with a direct
>>>> solver as I am not versed in SNES options.
>>>> Notwithstanding something strange is happening only on select examples.
>>>> With ksp/ksp/exampeles/tutorials/ex2.c and the run line:
>>>> -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 20 -n 20 -ksp_type preonly
>>>> I get good results (of the order):
>>>> Norm of error 1.85464e-14 iterations 1
>>>> using both superlu_dist and spooles.
>>>> My BLAS/LAPACK: -llapack -lblas (so native to my machine).
>>>> If you can guide me on a run line for the snes ex5.c I can try that too.
>>>> I'll also try to construct a GCC build later to see if that is an issue.
>>> Same line on ex5, but ex2 is good enough. However, it will not tell us
>>> anything new. Try another build.
>>>     Matt
>>>> -sanjay
>>>> On 12/23/12 5:58 PM, Matthew Knepley wrote:
>>>> On Sun, Dec 23, 2012 at 8:08 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>> wrote:
>>>>> Not sure what you mean by where is your matrix?  I am simply running
>>>>> ex6
>>>>> in the ksp/examples/tests directory.
>>>>> The reason I ran this test is because I was seeing the same behavior
>>>>> with
>>>>> my finite element code (on perfectly benign problems).
>>>>> Is there a built-in test that you use to check that superlu_dist is
>>>>> working properly with petsc?
>>>>> i.e. something you know that works with with petsc 3.3-p5?
>>>> 1) Run it on a SNES ex5 (or KSP ex2), which is a nice Laplacian
>>>> 2) Compare with MUMPS
>>>>     Matt
>>>>> -sanjay
>>>>> On 12/23/12 4:56 PM, Jed Brown wrote:
>>>>> Where is your matrix? It might be ending up with a very bad pivot. If
>>>>> the
>>>>> problem can be reproduced, it should be reported to the SuperLU_DIST
>>>>> developers to fix. (Note that we do not see this with other matrices.)
>>>>> You
>>>>> can also try MUMPS.
>>>>> On Sun, Dec 23, 2012 at 6:48 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>>> wrote:
>>>>>> I wanted to use SuperLU Dist to perform a direct solve but seem to be
>>>>>> encountering
>>>>>> a problem.  I was wonder if this is a know issue and if there is a
>>>>>> solution for it.
>>>>>> The problem is easily observed using ex6.c in
>>>>>> src/ksp/ksp/examples/tests.
>>>>>> Out of the box: make runex6 produces a residual error of O(1e-11), all
>>>>>> is well.
>>>>>> I then changed the run to run on two processors and add the flag
>>>>>> -pc_factor_mat_solver_package spooles  this produces a residual error
>>>>>> of
>>>>>> O(1e-11), all is still well.
>>>>>> I then switch over to -pc_factor_mat_solver_package superlu_dist and
>>>>>> the
>>>>>> residual error comes back as 22.6637!  Something seems very wrong.
>>>>>> My build is perfectly vanilla:
>>>>>> export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>>>>> export PETSC_ARCH=intel
>>>>>> ./configure --with-cc=icc --with-fc=ifort  \
>>>>>> -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
>>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel all
>>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel test
>>>>>> -sanjay
>>>>> Sanjay Govindjee, PhD, PE
>>>>> Professor of Civil Engineering
>>>>> Vice Chair for Academic Affairs
>>>>> 779 Davis Hall
>>>>> Structural Engineering, Mechanics and Materials
>>>>> Department of Civil Engineering
>>>>> University of California
>>>>> Berkeley, CA 94720-1710
>>>>> Voice:  +1 510 642 6060
>>>>> FAX:    +1 510 643 5264
>>>>> s_g at berkeley.edu
>>>>> http://www.ce.berkeley.edu/~sanjay
>>>>> New Books:
>>>>> Engineering Mechanics of Deformable
>>>>> Solids: A Presentation with Exercises
>>>>> http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>>>> http://ukcatalogue.oup.com/product/9780199651641.do
>>>>> http://amzn.com/0199651647
>>>>> Engineering Mechanics 3 (Dynamics)
>>>>> http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>>>>> http://amzn.com/3642140181
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments
>>> is infinitely more interesting than any results to which their
>>> experiments
>>> lead.
>>> -- Norbert Wiener
> 779 Davis Hall
> s_g at berkeley.edu
> New Books:
