[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Wed Dec 26 15:28:37 CST 2012
hmmm....I guess that is good news -- in that superlu is not broken.
However, for me
not so good news since I seems that there is nasty bug lurking on my
machine.
Any suggestions on chasing down the error?
On 12/26/12 1:23 PM, Hong Zhang wrote:
> Sanjay:
> I get
> petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2
> -ksp_monitor_short  -ksp_type preonly -pc_type lu
> -pc_factor_mat_solver_package superlu_dist -m 500 -n 500
> Norm of error 1.92279e-11 iterations 1
> Hong
>> I have done some more testing of the problem, continuing with
>> src/ksp/ksp/examples/tutorials/ex2.c.
>> The behavior I am seeing is that with smaller problems sizes superlu_dist is
>> behaving properly
>> but with larger problem sizes things seem to go wrong and what goes wrong is
>> apparently consistent; the error appears both with my intel build as well as
>> with my gcc build.
>> I have two run lines:
>> runex2superlu:
>>          -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 100 -n 100 -ksp_type
>> preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist
>> runex2spooles:
>> preonly -pc_type lu -pc_factor_mat_solver_package spooles
>>  From my intel build, I get
>> sg-macbook-prolocal:tutorials sg$ make runex2superlu
>> Norm of error 7.66145e-13 iterations 1
>> sg-macbook-prolocal:tutorials sg$ make runex2spooles
>> Norm of error 2.21422e-12 iterations 1
>>  From my GCC build, I get
>> If I change the -m 100 -n 100 to -m 500 -n 500, I get for my intel build
>> Norm of error 419.953 iterations 1
>> Norm of error 2.69468e-10 iterations 1
>>  From my GCC build with -m 500 -n 500, I get
>> Any suggestions will be greatly appreciated.
>> -sanjay
>> On 12/23/12 6:42 PM, Matthew Knepley wrote:
>> On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>>> I decided to go with ksp/ksp/exampeles/tutorials/ex2.c; I was unsure how
>>> to convert the run lines for snes/examples/ex5.c to work with a direct
>>> solver as I am not versed in SNES options.
>>> Notwithstanding something strange is happening only on select examples.
>>> With ksp/ksp/exampeles/tutorials/ex2.c and the run line:
>>> -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 20 -n 20 -ksp_type preonly
>>> I get good results (of the order):
>>> Norm of error 1.85464e-14 iterations 1
>>> using both superlu_dist and spooles.
>>> My BLAS/LAPACK: -llapack -lblas (so native to my machine).
>>> If you can guide me on a run line for the snes ex5.c I can try that too.
>>> I'll also try to construct a GCC build later to see if that is an issue.
>> Same line on ex5, but ex2 is good enough. However, it will not tell us
>> anything new. Try another build.
>>     Matt
>>> -sanjay
>>> On 12/23/12 5:58 PM, Matthew Knepley wrote:
>>> On Sun, Dec 23, 2012 at 8:08 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>> wrote:
>>>> Not sure what you mean by where is your matrix?  I am simply running ex6
>>>> in the ksp/examples/tests directory.
>>>> The reason I ran this test is because I was seeing the same behavior with
>>>> my finite element code (on perfectly benign problems).
>>>> Is there a built-in test that you use to check that superlu_dist is
>>>> working properly with petsc?
>>>> i.e. something you know that works with with petsc 3.3-p5?
>>> 1) Run it on a SNES ex5 (or KSP ex2), which is a nice Laplacian
>>> 2) Compare with MUMPS
>>>     Matt
>>>> -sanjay
>>>> On 12/23/12 4:56 PM, Jed Brown wrote:
>>>> Where is your matrix? It might be ending up with a very bad pivot. If the
>>>> problem can be reproduced, it should be reported to the SuperLU_DIST
>>>> developers to fix. (Note that we do not see this with other matrices.) You
>>>> can also try MUMPS.
>>>> On Sun, Dec 23, 2012 at 6:48 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>> wrote:
>>>>> I wanted to use SuperLU Dist to perform a direct solve but seem to be
>>>>> encountering
>>>>> a problem.  I was wonder if this is a know issue and if there is a
>>>>> solution for it.
>>>>> The problem is easily observed using ex6.c in
>>>>> src/ksp/ksp/examples/tests.
>>>>> Out of the box: make runex6 produces a residual error of O(1e-11), all
>>>>> is well.
>>>>> I then changed the run to run on two processors and add the flag
>>>>> -pc_factor_mat_solver_package spooles  this produces a residual error of
>>>>> O(1e-11), all is still well.
>>>>> I then switch over to -pc_factor_mat_solver_package superlu_dist and the
>>>>> residual error comes back as 22.6637!  Something seems very wrong.
>>>>> My build is perfectly vanilla:
>>>>> export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>>>> export PETSC_ARCH=intel
>>>>> ./configure --with-cc=icc --with-fc=ifort  \
>>>>> -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel all
>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel test
>>>>> -sanjay
>>>> Sanjay Govindjee, PhD, PE
>>>> Professor of Civil Engineering
>>>> Vice Chair for Academic Affairs
>>>> 779 Davis Hall
>>>> Structural Engineering, Mechanics and Materials
>>>> Department of Civil Engineering
>>>> University of California
>>>> Berkeley, CA 94720-1710
>>>> Voice:  +1 510 642 6060
>>>> FAX:    +1 510 643 5264
>>>> s_g at berkeley.edu
>>>> http://www.ce.berkeley.edu/~sanjay
>>>> New Books:
>>>> Engineering Mechanics of Deformable
>>>> Solids: A Presentation with Exercises
>>>> http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>>> http://ukcatalogue.oup.com/product/9780199651641.do
>>>> http://amzn.com/0199651647
>>>> Engineering Mechanics 3 (Dynamics)
>>>> http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>>>> http://amzn.com/3642140181
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
779 Davis Hall
s_g at berkeley.edu
New Books:
