[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Wed Dec 26 15:38:24 CST 2012
I have a macbook pro (Mac OS X 10.7.5)
% uname -a
Darwin sg-macbook-prolocal.local 11.4.2 Darwin Kernel Version 11.4.2:
Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
I configured using:
./configure --with-cc=icc --with-fc=ifort
-download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
so everything was built together.
On 12/26/12 1:34 PM, Hong Zhang wrote:
> Sanjay:
>> hmmm....I guess that is good news -- in that superlu is not broken. However,
>> for me
>> not so good news since I seems that there is nasty bug lurking on my
>> machine.
>> Any suggestions on chasing down the error?
> How did you install your supelu_dist with petsc-3.3?
> What machine do you use?
> Hong
>> On 12/26/12 1:23 PM, Hong Zhang wrote:
>>> Sanjay:
>>> I get
>>> petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2
>>> -ksp_monitor_short  -ksp_type preonly -pc_type lu
>>> -pc_factor_mat_solver_package superlu_dist -m 500 -n 500
>>> Norm of error 1.92279e-11 iterations 1
>>> Hong
>>>> I have done some more testing of the problem, continuing with
>>>> src/ksp/ksp/examples/tutorials/ex2.c.
>>>> The behavior I am seeing is that with smaller problems sizes superlu_dist
>>>> is
>>>> behaving properly
>>>> but with larger problem sizes things seem to go wrong and what goes wrong
>>>> is
>>>> apparently consistent; the error appears both with my intel build as well
>>>> as
>>>> with my gcc build.
>>>> I have two run lines:
>>>> runex2superlu:
>>>>           -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 100 -n 100
>>>> -ksp_type
>>>> preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist
>>>> runex2spooles:
>>>> -ksp_type
>>>> preonly -pc_type lu -pc_factor_mat_solver_package spooles
>>>>   From my intel build, I get
>>>> sg-macbook-prolocal:tutorials sg$ make runex2superlu
>>>> Norm of error 7.66145e-13 iterations 1
>>>> sg-macbook-prolocal:tutorials sg$ make runex2spooles
>>>> Norm of error 2.21422e-12 iterations 1
>>>>   From my GCC build, I get
>>>> If I change the -m 100 -n 100 to -m 500 -n 500, I get for my intel build
>>>> Norm of error 419.953 iterations 1
>>>> Norm of error 2.69468e-10 iterations 1
>>>>   From my GCC build with -m 500 -n 500, I get
>>>> Any suggestions will be greatly appreciated.
>>>> -sanjay
>>>> On 12/23/12 6:42 PM, Matthew Knepley wrote:
>>>> On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>> wrote:
>>>>> I decided to go with ksp/ksp/exampeles/tutorials/ex2.c; I was unsure how
>>>>> to convert the run lines for snes/examples/ex5.c to work with a direct
>>>>> solver as I am not versed in SNES options.
>>>>> Notwithstanding something strange is happening only on select examples.
>>>>> With ksp/ksp/exampeles/tutorials/ex2.c and the run line:
>>>>> -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 20 -n 20 -ksp_type preonly
>>>>> I get good results (of the order):
>>>>> Norm of error 1.85464e-14 iterations 1
>>>>> using both superlu_dist and spooles.
>>>>> My BLAS/LAPACK: -llapack -lblas (so native to my machine).
>>>>> If you can guide me on a run line for the snes ex5.c I can try that too.
>>>>> I'll also try to construct a GCC build later to see if that is an issue.
>>>> Same line on ex5, but ex2 is good enough. However, it will not tell us
>>>> anything new. Try another build.
>>>>      Matt
>>>>> -sanjay
>>>>> On 12/23/12 5:58 PM, Matthew Knepley wrote:
>>>>> On Sun, Dec 23, 2012 at 8:08 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>>> wrote:
>>>>>> Not sure what you mean by where is your matrix?  I am simply running
>>>>>> ex6
>>>>>> in the ksp/examples/tests directory.
>>>>>> The reason I ran this test is because I was seeing the same behavior
>>>>>> with
>>>>>> my finite element code (on perfectly benign problems).
>>>>>> Is there a built-in test that you use to check that superlu_dist is
>>>>>> working properly with petsc?
>>>>>> i.e. something you know that works with with petsc 3.3-p5?
>>>>> 1) Run it on a SNES ex5 (or KSP ex2), which is a nice Laplacian
>>>>> 2) Compare with MUMPS
>>>>>      Matt
>>>>>> -sanjay
>>>>>> On 12/23/12 4:56 PM, Jed Brown wrote:
>>>>>> Where is your matrix? It might be ending up with a very bad pivot. If
>>>>>> the
>>>>>> problem can be reproduced, it should be reported to the SuperLU_DIST
>>>>>> developers to fix. (Note that we do not see this with other matrices.)
>>>>>> You
>>>>>> can also try MUMPS.
>>>>>> On Sun, Dec 23, 2012 at 6:48 PM, Sanjay Govindjee <s_g at berkeley.edu>
>>>>>> wrote:
>>>>>>> I wanted to use SuperLU Dist to perform a direct solve but seem to be
>>>>>>> encountering
>>>>>>> a problem.  I was wonder if this is a know issue and if there is a
>>>>>>> solution for it.
>>>>>>> The problem is easily observed using ex6.c in
>>>>>>> src/ksp/ksp/examples/tests.
>>>>>>> Out of the box: make runex6 produces a residual error of O(1e-11), all
>>>>>>> is well.
>>>>>>> I then changed the run to run on two processors and add the flag
>>>>>>> -pc_factor_mat_solver_package spooles  this produces a residual error
>>>>>>> of
>>>>>>> O(1e-11), all is still well.
>>>>>>> I then switch over to -pc_factor_mat_solver_package superlu_dist and
>>>>>>> the
>>>>>>> residual error comes back as 22.6637!  Something seems very wrong.
>>>>>>> My build is perfectly vanilla:
>>>>>>> export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>>>>>> export PETSC_ARCH=intel
>>>>>>> ./configure --with-cc=icc --with-fc=ifort  \
>>>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel all
>>>>>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel test
>>>>>>> -sanjay
>>>>>> Sanjay Govindjee, PhD, PE
>>>>>> Professor of Civil Engineering
>>>>>> Vice Chair for Academic Affairs
>>>>>> 779 Davis Hall
>>>>>> Structural Engineering, Mechanics and Materials
>>>>>> Department of Civil Engineering
>>>>>> University of California
>>>>>> Berkeley, CA 94720-1710
>>>>>> Voice:  +1 510 642 6060
>>>>>> FAX:    +1 510 643 5264
>>>>>> s_g at berkeley.edu
>>>>>> http://www.ce.berkeley.edu/~sanjay
>>>>>> New Books:
>>>>>> Engineering Mechanics of Deformable
>>>>>> Solids: A Presentation with Exercises
>>>>>> http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>>>>> http://ukcatalogue.oup.com/product/9780199651641.do
>>>>>> http://amzn.com/0199651647
>>>>>> Engineering Mechanics 3 (Dynamics)
>>>>>> http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>>>>>> http://amzn.com/3642140181
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which
>>>>> their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments
>>>> is infinitely more interesting than any results to which their
>>>> experiments
>>>> lead.
>>>> -- Norbert Wiener
>> 779 Davis Hall
>> s_g at berkeley.edu
>> New Books:
779 Davis Hall
s_g at berkeley.edu
New Books:
