[petsc-users] Problem with fortran version of ex29 in ksp
Thu Apr 26 07:45:22 CDT 2012
On Thu, Apr 26, 2012 at 8:27 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Hi,
> Is there an answer to the question below?
>  I still can't get it working.
> Thanks.
> Hi,
> There's no error now but I didn't get the same ans as ex29. I believe the
> error lies in the boundary evaluation of v.
> In c, the code is :
> else if (user->bcType == NEUMANN) {
>           num = 0;
>           if (j!=0) {
>             v[num] = -rho*HxdHy;              col[num].i = i;   col[num].j
> = j-1;
        ^^^ See
this?
>             num++;
>           if (i!=0) {
>             v[num] = -rho*HydHx;              col[num].i = i-1; col[num].j
> = j;
>             num++;
>           if (i!=mx-1) {
>             v[num] = -rho*HydHx;              col[num].i = i+1; col[num].j
> = j;
>             num++;
>           if (j!=my-1) {
> = j+1;
>             num++;
>           v[num]   = (num/2.0)*rho*(HxdHy + HydHx); col[num].i = i;
> col[num].j = j;
>           num++;
>           ierr =
> MatSetValuesStencil(jac,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
> In fortran, I have changed to :
> else if (bc_cond == 2) then
>                 num = 1
>                 if (j/=0) then
>                     v(num) = -rho*HxdHy
>                     col(MatStencil_i,1) = i
                                               ^^ Why is this 1 in stead of
'num'?
   Matt
                    col(MatStencil_j,2) = j-1
>                     num = num + 1
>                 end if
>                 if (i/=0) then
>                     v(num) = -rho*HydHx
>                     col(MatStencil_i,1) = i-1
>                     num = num + 1
>                 end if
>                 if (i/=mx-1) then
>                     v(num) = -rho*HydHx
>                     col(MatStencil_i,1) = i+1
>                     num = num + 1
>                 end if
>                 if (j/=my-1) then
>                     v(num) = -rho*HxdHy
>                     col(MatStencil_j,2) = j+1
>                     num = num + 1
>                 end if
>                 v(num) = (num/2.0)*rho*(HxdHy + HydHx)
>                 num = num + 1
>                 call
> MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
> However, I got the error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range!
> [0]PETSC ERROR: New nonzero at (1,3) caused a malloc!
> [0]PETSC ERROR:
> How such is be defined in Fortran?
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 25/4/2012 12:06 AM, Matthew Knepley wrote:
> On Tue, Apr 24, 2012 at 4:57 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  Hi,
>> I still got the same error the moment this subroutine is called, after
>> changing to :
>> call
>> MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_OBJECT,nullspace,ierr)
>  Argument 3 should be 0.
>    Matt
>>  [0]PETSC ERROR: Null argument, when expecting valid pointer!
>> [0]PETSC ERROR: Null Object: Parameter # 4!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> fc934c1d84bc6ba8e2686702a8a99539d
>> 50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a petsc-3.2 named
>> USER-PC by
>>  User Tue Apr 24 22:54:50 2012
>> [0]PETSC ERROR: Libraries linked from
>> /cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>> /lib
>> [0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
>> [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>> --with-fc="win32fe ifor
>> t" --with-cxx="win32fe cl" --with-mpi-dir=/cygdrive/d/Lib/MPICH2/
>> --download-f-b
>> las-lapack=1 --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>> --with-debuggin
>> g=1 --useThreads=0
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatNullSpaceCreate() line 250 in
>> src/mat/interface/C:\temp\PETSC
>> -~1\src\mat\INTERF~1\matnull.c
>> Yours sincerely,
>> TAY wee-beng
>> On 24/4/2012 10:37 PM, Matthew Knepley wrote:
>> On Tue, Apr 24, 2012 at 4:32 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>  Hi,
>>> I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from c to fortran
>>> version. The fortran version is based on the template of ex22f, which is in
>>> 3d.
>>> I have attached the code below. I have 2 problems.
>>> 1. When i3 = -3, in dirichlet BC, I got the same answer as ex29 in c
>>> version.
>>> However, when I change i3 to -4, I got the following error:
>>> [0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> USER-PC by
>>>  User Tue Apr 24 22:08:46 2012
>>> /lib
>>> --download-f-b
>>> --with-debuggin
>>> g=1 --useThreads=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
>>> src/mat/impls/aij/seq/C:\temp\
>>> PETSC-~1\src\mat\impls\aij\seq\aij.c
>>> [0]PETSC ERROR: MatSetValues() line 1148 in
>>> src/mat/interface/C:\temp\PETSC-~1\s
>>> rc\mat\INTERF~1\matrix.c
>>> [0]PETSC ERROR: MatSetValuesLocal() line 2003 in
>>> -~1\src\mat\INTERF~1\matrix.c
>>> [0]PETSC ERROR: MatSetValuesStencil() line 1379 in
>>> SC-~1\src\mat\INTERF~1\matrix.c
>>> [0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
>>> What did I do wrong?
>>> 2. When I wanted to use the neumann BC, following ex29, I added :
>>> In subroutine ComputeRHS
>>> call
>>> MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
>>> call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>> call MatNullSpaceDestroy(nullspace,ierr)
>>> and in subroutine ComputeMatrix
>>> call
>>> call MatSetNullSpace(jac,nullspace,ierr)
>>> When I compile, it says unresolved external symbol MatNullSpaceRemove.
>>> Removing MatNullSpaceRemove, I can compile but running gives the error:
>>> [0]PETSC ERROR: Corrupt argument:
>>> see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>>> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 4!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> USER-PC by
>>>  User Tue Apr 24 22:30:31 2012
>>> /lib
>>> --download-f-b
>>> --with-debuggin
>>> g=1 --useThreads=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Invalid argument!
>>> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> USER-PC by
>>> /lib
>>> --download-f-b
>>> --with-debuggin
>>> g=1 --useThreads=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
>>> C-~1\src\mat\INTERF~1\matnull.c
>>> [0]PETSC ERROR: ourdmfunction() line 30 in
>>> src/dm/interface/ftn-custom/C:\temp\P
>>> ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
>>> [0]PETSC ERROR: DMComputeFunction() line 1783 in
>>> src/dm/interface/C:\temp\PETSC-
>>> ~1\src\dm\INTERF~1\dm.c
>>> [0]PETSC ERROR: KSPSetUp() line 218 in
>>> src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
>>> c\ksp\ksp\INTERF~1\itfunc.c
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> USER-PC by
>>> /lib
>>> --download-f-b
>>> --with-debuggin
>>> g=1 --useThreads=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> USER-PC by
>>> /lib
>>> --download-f-b
>>> --with-debuggin
>>> g=1 --useThreads=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: KSPSolve() line 402 in
>>> Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>   type: mpi
>>> Process [0]
>>> What's wrong?
>>> *program ex29f*
>>> implicit none
>>> !                    Include files
>>> !     petscsys.h  - base PETSc routines      petscvec.h - vectors
>>> !     petscmat.h - matrices
>>> !     petscksp.h    - Krylov subspace methods  petscpc.h  -
>>> preconditioners
>>> #include "finclude/petsc.h90"
>>> PetscErrorCode   ierr
>>> DM               da
>>> KSP              ksp
>>> Vec              x
>>> external         ComputeRHS,ComputeMatrix
>>> PetscInt i1,i3
>>> call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>> i3 = -4
>>> i1 = 1
>>> call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>> call
>>> DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>> call DMSetFunction(da,ComputeRHS,ierr)
>>> call DMSetJacobian(da,ComputeMatrix,ierr)
>>> call KSPSetDM(ksp,da,ierr)
>>> call KSPSetFromOptions(ksp,ierr)
>>> call KSPSetUp(ksp,ierr)
>>> call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>>> call KSPGetSolution(ksp,x,ierr)
>>> call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>> call KSPDestroy(ksp,ierr)
>>> call DMDestroy(da,ierr)
>>> call PetscFinalize(ierr)
>>> end program ex29f
>>> subroutine ComputeRHS(da,x,b,ierr)
>>> implicit none
>>> PetscErrorCode  ierr
>>> PetscInt i,j,mx,my,xm,ym,xs,ys
>>> PetscScalar  h,nu,rho
>>> PetscScalar Hx,Hy
>>> PetscScalar,pointer :: array(:,:)
>>> Vec          x,b
>>> DM           da
>>> MatNullSpace nullspace    !>neumann BC
>>> nu = 0.1
>>> call
>>> DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
>>> Hx = 1.d0 / (mx-1)
>>> Hy = 1.d0 / (my-1)
>>> call
>>> DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>>> call DMDAVecGetArrayF90(da,b,array,ierr)
>>> do j = ys,ys+ym-1
>>>     do i = xs,xs+xm-1
>>>         array(i,j) = exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>>>     end do
>>> end do
>>> call DMDAVecRestoreArrayF90(da,b,array,ierr)
>>> call VecAssemblyBegin(b,ierr)
>>> call VecAssemblyEnd(b,ierr)
>>> !call
>>  4th argument should be PETSC_NULL_OBJECT.
>>     Matt
>>>  !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>> !call MatNullSpaceDestroy(nullspace,ierr)
>>> end subroutine ComputeRHS
>>> subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
>>> implicit none
>>> Mat          jac,JJ
>>> PetscErrorCode    ierr
>>> DM           da
>>> PetscInt    i,j,k,mx,my,xm
>>> PetscInt    ym,xs,ys,i1,i5
>>> PetscScalar  v(5),Hx,Hy,rho,centerRho
>>> PetscScalar  HydHx
>>> PetscScalar  HxdHy
>>> MatStencil   row(4),col(4,5)
>>> Vec          x
>>> MatStructure str
>>> rho = 1.0
>>> i1 = 1
>>> i5 = 5
>>> centerRho = rho
>>> call
>>> Hx = 1.d0 / (mx-1)
>>> Hy = 1.d0 / (my-1)
>>> HxdHy = Hx/Hy
>>> HydHx = Hy/Hx
>>> call
>>> do j=ys,ys+ym-1
>>>     do i=xs,xs+xm-1
>>>         row(MatStencil_i) = i
>>>         row(MatStencil_j) = j
>>>         call ComputeRho(i,j,mx,my,centerRho,rho)
>>>         if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or. j.eq.my-1) then
>>>             v(1) = 2.0*rho*(HxdHy + HydHx)
>>>             call
>>> MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
>>>         else
>>>             v(1) = -rho*HxdHy
>>  Cut and paste error above.
>>    Matt
>>>              v(2) = -rho*HydHx
>>>             col(MatStencil_i,2) = i-1
>>>             v(3) = 2.0*rho*(HxdHy + HydHx)
>>>             col(MatStencil_i,3) = i
>>>             col(MatStencil_j,3) = j
>>>             v(4) = -rho*HydHx
>>>             col(MatStencil_i,4) = i+1
>>>             col(MatStencil_j,4) = j
>>>             v(5) = -rho*HxdHy
>>>             col(MatStencil_i,5) = i
>>>             col(MatStencil_j,5) = j+1
>>>             call
>>> MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
>>>         end if
>>>     end do
>>> end do
>>> call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
>>> call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
>>> !call
>>> !call MatSetNullSpace(jac,nullspace,ierr)
>>> end subroutine ComputeMatrix
>>> subroutine ComputeRho(i,j,mx,my,centerRho,rho)
>>> PetscInt    i,j,mx,my
>>> PetscScalar  rho,centerRho
>>> if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j > my/3.0) .and. (j <
>>> 2.0*my/3.0)) then
>>>     rho = centerRho
>>> else
>>>     rho = 1.0
>>> end if
>>> end subroutine ComputeRho
>>> Yours sincerely,
>>> TAY wee-beng
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120426/4a2ae495/attachment-0001.htm>
