[petsc-users] Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Thu Apr 26 14:26:19 CDT 2012
Thanks for pointing out my mistake. I'm still learning about the code. I
corrected but I still get the error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (2,4) caused a malloc!
[0]PETSC ERROR:
boundary condition region:
num = 1
                 if (j/=0) then
                     v(num) = -rho*HxdHy
                     col(MatStencil_i,num) = i
                     col(MatStencil_j,num) = j-1
                     num = num + 1
                 end if
                 if (i/=0) then
                     v(num) = -rho*HydHx
                     col(MatStencil_i,num) = i-1
                     num = num + 1
                 end if
                 if (i/=mx-1) then
                     v(num) = -rho*HydHx
                     col(MatStencil_i,num) = i+1
                     num = num + 1
                 end if
                 if (j/=my-1) then
                     v(num) = -rho*HxdHy
                     col(MatStencil_j,num) = j+1
                     num = num + 1
                 end if
                 v(num) = (num/2.0)*rho*(HxdHy + HydHx)
                 num = num + 1
                 call
MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
Yours sincerely,
TAY wee-beng
On 26/4/2012 2:45 PM, Matthew Knepley wrote:
> On Thu, Apr 26, 2012 at 8:27 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     Is there an answer to the question below?
>      I still can't get it working.
>     Thanks.
>     Hi,
>     There's no error now but I didn't get the same ans as ex29. I
>     believe the error lies in the boundary evaluation of v.
>     In c, the code is :
>     else if (user->bcType == NEUMANN) {
>               num = 0;
>               if (j!=0) {
>                 v[num] = -rho*HxdHy;              col[num].i = i;
>     col[num].j = j-1;
> See this?
>                 num++;
>               if (i!=0) {
>                 v[num] = -rho*HydHx;              col[num].i = i-1;
>     col[num].j = j;
>                 num++;
>               if (i!=mx-1) {
>                 v[num] = -rho*HydHx;              col[num].i = i+1;
>     col[num].j = j;
>                 num++;
>               if (j!=my-1) {
>     col[num].j = j+1;
>                 num++;
>               v[num]   = (num/2.0)*rho*(HxdHy + HydHx); col[num].i =
>     i;   col[num].j = j;
>               num++;
>               ierr =
>     MatSetValuesStencil(jac,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>     In fortran, I have changed to :
>     else if (bc_cond == 2) then
>                     num = 1
>                     if (j/=0) then
>                         v(num) = -rho*HxdHy
>                         col(MatStencil_i,1) = i
>                                                ^^ Why is this 1 in
> stead of 'num'?
>    Matt
>                         col(MatStencil_j,2) = j-1
>                         num = num + 1
>                     end if
>                     if (i/=0) then
>                         v(num) = -rho*HydHx
>                         col(MatStencil_i,1) = i-1
>                         num = num + 1
>                     end if
>                     if (i/=mx-1) then
>                         v(num) = -rho*HydHx
>                         col(MatStencil_i,1) = i+1
>                         num = num + 1
>                     end if
>                     if (j/=my-1) then
>                         v(num) = -rho*HxdHy
>                         col(MatStencil_j,2) = j+1
>                         num = num + 1
>                     end if
>                     num = num + 1
>                     call
>     However, I got the error:
>     [0]PETSC ERROR: New nonzero at (1,3) caused a malloc!
>     [0]PETSC ERROR:
>     How such is be defined in Fortran?
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 25/4/2012 12:06 AM, Matthew Knepley wrote:
>>     On Tue, Apr 24, 2012 at 4:57 PM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         I still got the same error the moment this subroutine is
>>         called, after changing to :
>>         call
>>         MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_OBJECT,nullspace,ierr)
>>     Argument 3 should be 0.
>>       Matt
>>         [0]PETSC ERROR: Null argument, when expecting valid pointer!
>>         [0]PETSC ERROR: Null Object: Parameter # 4!
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: Petsc Development HG revision:
>>         fc934c1d84bc6ba8e2686702a8a99539d
>>         50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
>>         [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>         [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>         shooting.
>>         [0]PETSC ERROR: See docs/index.html for manual pages.
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a
>>         petsc-3.2 named USER-PC by
>>          User Tue Apr 24 22:54:50 2012
>>         [0]PETSC ERROR: Libraries linked from
>>         /cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>>         /lib
>>         [0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
>>         [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>>         --with-fc="win32fe ifor
>>         t" --with-cxx="win32fe cl"
>>         --with-mpi-dir=/cygdrive/d/Lib/MPICH2/ --download-f-b
>>         las-lapack=1
>>         --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: MatNullSpaceCreate() line 250 in
>>         src/mat/interface/C:\temp\PETSC
>>         -~1\src\mat\INTERF~1\matnull.c
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 24/4/2012 10:37 PM, Matthew Knepley wrote:
>>>         On Tue, Apr 24, 2012 at 4:32 PM, TAY wee-beng
>>>         <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>>             Hi,
>>>             I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from c to
>>>             fortran version. The fortran version is based on the
>>>             template of ex22f, which is in 3d.
>>>             I have attached the code below. I have 2 problems.
>>>             1. When i3 = -3, in dirichlet BC, I got the same answer
>>>             as ex29 in c version.
>>>             However, when I change i3 to -4, I got the following error:
>>>             [0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
>>>             [0]PETSC ERROR:
>>>             updates.
>>>             trouble shooting.
>>>             [0]PETSC ERROR:
>>>              User Tue Apr 24 22:08:46 2012
>>>             /lib
>>>             las-lapack=1
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
>>>             src/mat/impls/aij/seq/C:\temp\
>>>             PETSC-~1\src\mat\impls\aij\seq\aij.c
>>>             [0]PETSC ERROR: MatSetValues() line 1148 in
>>>             src/mat/interface/C:\temp\PETSC-~1\s
>>>             rc\mat\INTERF~1\matrix.c
>>>             [0]PETSC ERROR: MatSetValuesLocal() line 2003 in
>>>             -~1\src\mat\INTERF~1\matrix.c
>>>             [0]PETSC ERROR: MatSetValuesStencil() line 1379 in
>>>             SC-~1\src\mat\INTERF~1\matrix.c
>>>             [0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
>>>             What did I do wrong?
>>>             2. When I wanted to use the neumann BC, following ex29,
>>>             I added :
>>>             In subroutine ComputeRHS
>>>             call
>>>             MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
>>>             call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>             call MatNullSpaceDestroy(nullspace,ierr)
>>>             and in subroutine ComputeMatrix
>>>             call
>>>             call MatSetNullSpace(jac,nullspace,ierr)
>>>             When I compile, it says unresolved external symbol
>>>             MatNullSpaceRemove. Removing MatNullSpaceRemove, I can
>>>             compile but running gives the error:
>>>             [0]PETSC ERROR: Corrupt argument:
>>>             see
>>>             http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>>>             [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 4!
>>>             [0]PETSC ERROR:
>>>             updates.
>>>             trouble shooting.
>>>             [0]PETSC ERROR:
>>>              User Tue Apr 24 22:30:31 2012
>>>             /lib
>>>             las-lapack=1
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: Invalid argument!
>>>             [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>>             [0]PETSC ERROR:
>>>             updates.
>>>             trouble shooting.
>>>             [0]PETSC ERROR:
>>>             /lib
>>>             las-lapack=1
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
>>>             C-~1\src\mat\INTERF~1\matnull.c
>>>             [0]PETSC ERROR: ourdmfunction() line 30 in
>>>             src/dm/interface/ftn-custom/C:\temp\P
>>>             ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
>>>             [0]PETSC ERROR: DMComputeFunction() line 1783 in
>>>             src/dm/interface/C:\temp\PETSC-
>>>             ~1\src\dm\INTERF~1\dm.c
>>>             [0]PETSC ERROR: KSPSetUp() line 218 in
>>>             src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
>>>             c\ksp\ksp\INTERF~1\itfunc.c
>>>             see
>>>             [0]PETSC ERROR:
>>>             updates.
>>>             trouble shooting.
>>>             [0]PETSC ERROR:
>>>             /lib
>>>             las-lapack=1
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR:
>>>             updates.
>>>             trouble shooting.
>>>             [0]PETSC ERROR:
>>>             /lib
>>>             las-lapack=1
>>>             --with-debuggin
>>>             g=1 --useThreads=0
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: KSPSolve() line 402 in
>>>             Vector Object:Vec_0000000084000000_0 1 MPI processes
>>>               type: mpi
>>>             Process [0]
>>>             What's wrong?
>>>             *program ex29f*
>>>             implicit none
>>>             !                    Include files
>>>             !     petscsys.h  - base PETSc routines      petscvec.h
>>>             - vectors
>>>             !     petscmat.h - matrices
>>>             !     petscksp.h    - Krylov subspace methods
>>>             petscpc.h  - preconditioners
>>>             #include "finclude/petsc.h90"
>>>             PetscErrorCode   ierr
>>>             DM               da
>>>             KSP              ksp
>>>             Vec              x
>>>             external         ComputeRHS,ComputeMatrix
>>>             PetscInt i1,i3
>>>             call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>             i3 = -4
>>>             i1 = 1
>>>             call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>>             call
>>>             DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>>             call DMSetFunction(da,ComputeRHS,ierr)
>>>             call DMSetJacobian(da,ComputeMatrix,ierr)
>>>             call KSPSetDM(ksp,da,ierr)
>>>             call KSPSetFromOptions(ksp,ierr)
>>>             call KSPSetUp(ksp,ierr)
>>>             call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>>>             call KSPGetSolution(ksp,x,ierr)
>>>             call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>             call KSPDestroy(ksp,ierr)
>>>             call DMDestroy(da,ierr)
>>>             call PetscFinalize(ierr)
>>>             end program ex29f
>>>             subroutine ComputeRHS(da,x,b,ierr)
>>>             implicit none
>>>             PetscErrorCode  ierr
>>>             PetscInt i,j,mx,my,xm,ym,xs,ys
>>>             PetscScalar  h,nu,rho
>>>             PetscScalar Hx,Hy
>>>             PetscScalar,pointer :: array(:,:)
>>>             Vec          x,b
>>>             DM           da
>>>             MatNullSpace nullspace    !>neumann BC
>>>             nu = 0.1
>>>             call
>>>             DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
>>>             Hx = 1.d0 / (mx-1)
>>>             Hy = 1.d0 / (my-1)
>>>             call
>>>             DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>>>             call DMDAVecGetArrayF90(da,b,array,ierr)
>>>             do j = ys,ys+ym-1
>>>                 do i = xs,xs+xm-1
>>>                     array(i,j) =
>>>             exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>>>                 end do
>>>             end do
>>>             call DMDAVecRestoreArrayF90(da,b,array,ierr)
>>>             call VecAssemblyBegin(b,ierr)
>>>             call VecAssemblyEnd(b,ierr)
>>>             !call
>>>         4th argument should be PETSC_NULL_OBJECT.
>>>            Matt
>>>             !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>>             !call MatNullSpaceDestroy(nullspace,ierr)
>>>             end subroutine ComputeRHS
>>>             subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
>>>             implicit none
>>>             Mat          jac,JJ
>>>             PetscErrorCode    ierr
>>>             DM           da
>>>             PetscInt    i,j,k,mx,my,xm
>>>             PetscInt    ym,xs,ys,i1,i5
>>>             PetscScalar  v(5),Hx,Hy,rho,centerRho
>>>             PetscScalar  HydHx
>>>             PetscScalar  HxdHy
>>>             MatStencil   row(4),col(4,5)
>>>             Vec          x
>>>             MatStructure str
>>>             rho = 1.0
>>>             i1 = 1
>>>             i5 = 5
>>>             centerRho = rho
>>>             call
>>>             Hx = 1.d0 / (mx-1)
>>>             Hy = 1.d0 / (my-1)
>>>             HxdHy = Hx/Hy
>>>             HydHx = Hy/Hx
>>>             call
>>>             do j=ys,ys+ym-1
>>>                 do i=xs,xs+xm-1
>>>                     row(MatStencil_i) = i
>>>                     row(MatStencil_j) = j
>>>                     call ComputeRho(i,j,mx,my,centerRho,rho)
>>>                     if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or.
>>>             j.eq.my-1) then
>>>                         v(1) = 2.0*rho*(HxdHy + HydHx)
>>>                         call
>>>             MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
>>>                     else
>>>                         v(1) = -rho*HxdHy
>>>         Cut and paste error above.
>>>           Matt
>>>                         v(2) = -rho*HydHx
>>>                         col(MatStencil_i,2) = i-1
>>>                         v(3) = 2.0*rho*(HxdHy + HydHx)
>>>                         col(MatStencil_i,3) = i
>>>                         col(MatStencil_j,3) = j
>>>                         v(4) = -rho*HydHx
>>>                         col(MatStencil_i,4) = i+1
>>>                         col(MatStencil_j,4) = j
>>>                         v(5) = -rho*HxdHy
>>>                         col(MatStencil_i,5) = i
>>>                         col(MatStencil_j,5) = j+1
>>>                         call
>>>             MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
>>>                     end if
>>>                 end do
>>>             end do
>>>             call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
>>>             call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
>>>             !call
>>>             !call MatSetNullSpace(jac,nullspace,ierr)
>>>             end subroutine ComputeMatrix
>>>             subroutine ComputeRho(i,j,mx,my,centerRho,rho)
>>>             PetscInt    i,j,mx,my
>>>             PetscScalar  rho,centerRho
>>>             if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j >
>>>             my/3.0) .and. (j < 2.0*my/3.0)) then
>>>                 rho = centerRho
>>>             else
>>>                 rho = 1.0
>>>             end if
>>>             end subroutine ComputeRho
>>>             Yours sincerely,
>>>             TAY wee-beng
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120426/0dc3969b/attachment-0001.htm>
