[petsc-users] Problem with fortran version of ex29 in ksp
TAY wee-beng zonexo at gmail.com
Thu Apr 26 07:27:09 CDT 2012
Is there an answer to the question below?
  I still can't get it working.
Thanks.
There's no error now but I didn't get the same ans as ex29. I believe
the error lies in the boundary evaluation of v.
In c, the code is :
else if (user->bcType == NEUMANN) {
           num = 0;
           if (j!=0) {
             v[num] = -rho*HxdHy;              col[num].i = i;
col[num].j = j-1;
             num++;
           if (i!=0) {
             v[num] = -rho*HydHx;              col[num].i = i-1;
col[num].j = j;
             num++;
           if (i!=mx-1) {
             v[num] = -rho*HydHx;              col[num].i = i+1;
col[num].j = j;
             num++;
           if (j!=my-1) {
col[num].j = j+1;
             num++;
           v[num]   = (num/2.0)*rho*(HxdHy + HydHx); col[num].i = i;
col[num].j = j;
           num++;
           ierr =
MatSetValuesStencil(jac,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
In fortran, I have changed to :
else if (bc_cond == 2) then
                 num = 1
                 if (j/=0) then
                     v(num) = -rho*HxdHy
                     col(MatStencil_i,1) = i
                     col(MatStencil_j,2) = j-1
                     num = num + 1
                 end if
                 if (i/=0) then
                     v(num) = -rho*HydHx
                     col(MatStencil_i,1) = i-1
                     num = num + 1
                 end if
                 if (i/=mx-1) then
                     v(num) = -rho*HydHx
                     col(MatStencil_i,1) = i+1
                     num = num + 1
                 end if
                 if (j/=my-1) then
                     v(num) = -rho*HxdHy
                     col(MatStencil_j,2) = j+1
                     num = num + 1
                 end if
                 v(num) = (num/2.0)*rho*(HxdHy + HydHx)
                 num = num + 1
                 call
MatSetValuesStencil(jac,i1,row,num,col,v,INSERT_VALUES,ierr)
However, I got the error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (1,3) caused a malloc!
[0]PETSC ERROR:
How such is be defined in Fortran?
Thank you
Yours sincerely,
TAY wee-beng
On 25/4/2012 12:06 AM, Matthew Knepley wrote:
> On Tue, Apr 24, 2012 at 4:57 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I still got the same error the moment this subroutine is called,
>     after changing to :
>     call
>     MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_OBJECT,nullspace,ierr)
> Argument 3 should be 0.
>   Matt
>     [0]PETSC ERROR: Null argument, when expecting valid pointer!
>     [0]PETSC ERROR: Null Object: Parameter # 4!
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Development HG revision:
>     fc934c1d84bc6ba8e2686702a8a99539d
>     50af122  HG Date: Mon Apr 23 11:39:32 2012 -0500
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: c:\obj_tmp\ex29f\Debug\ex29f.exe on a petsc-3.2
>     named USER-PC by
>      User Tue Apr 24 22:54:50 2012
>     [0]PETSC ERROR: Libraries linked from
>     /cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>     /lib
>     [0]PETSC ERROR: Configure run at Mon Apr 23 21:45:20 2012
>     [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>     --with-fc="win32fe ifor
>     t" --with-cxx="win32fe cl" --with-mpi-dir=/cygdrive/d/Lib/MPICH2/
>     --download-f-b
>     las-lapack=1 --prefix=/cygdrive/d/Lib/petsc-3.2-dev_win32_vs2008
>     --with-debuggin
>     g=1 --useThreads=0
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: MatNullSpaceCreate() line 250 in
>     src/mat/interface/C:\temp\PETSC
>     -~1\src\mat\INTERF~1\matnull.c
>     Yours sincerely,
>     TAY wee-beng
>     On 24/4/2012 10:37 PM, Matthew Knepley wrote:
>>     On Tue, Apr 24, 2012 at 4:32 PM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         I'm trying to rewrite ex29 (KSP^Laplacian, 2d) from c to
>>         fortran version. The fortran version is based on the template
>>         of ex22f, which is in 3d.
>>         I have attached the code below. I have 2 problems.
>>         1. When i3 = -3, in dirichlet BC, I got the same answer as
>>         ex29 in c version.
>>         However, when I change i3 to -4, I got the following error:
>>         [0]PETSC ERROR: New nonzero at (9,1) caused a malloc!
>>         [0]PETSC ERROR:
>>         shooting.
>>         [0]PETSC ERROR:
>>         petsc-3.2 named USER-PC by
>>          User Tue Apr 24 22:08:46 2012
>>         /lib
>>         --with-mpi-dir=/cygdrive/d/Lib/MPICH2/ --download-f-b
>>         las-lapack=1
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
>>         src/mat/impls/aij/seq/C:\temp\
>>         PETSC-~1\src\mat\impls\aij\seq\aij.c
>>         [0]PETSC ERROR: MatSetValues() line 1148 in
>>         src/mat/interface/C:\temp\PETSC-~1\s
>>         rc\mat\INTERF~1\matrix.c
>>         [0]PETSC ERROR: MatSetValuesLocal() line 2003 in
>>         -~1\src\mat\INTERF~1\matrix.c
>>         [0]PETSC ERROR: MatSetValuesStencil() line 1379 in
>>         SC-~1\src\mat\INTERF~1\matrix.c
>>         [0]PETSC ERROR: New nonzero at (10,2) caused a malloc!
>>         What did I do wrong?
>>         2. When I wanted to use the neumann BC, following ex29, I added :
>>         In subroutine ComputeRHS
>>         call
>>         MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,nullspace,ierr)
>>         call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>         call MatNullSpaceDestroy(nullspace,ierr)
>>         and in subroutine ComputeMatrix
>>         call
>>         call MatSetNullSpace(jac,nullspace,ierr)
>>         When I compile, it says unresolved external symbol
>>         MatNullSpaceRemove. Removing MatNullSpaceRemove, I can
>>         compile but running gives the error:
>>         [0]PETSC ERROR: Corrupt argument:
>>         see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>>         [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 4!
>>         [0]PETSC ERROR:
>>         shooting.
>>         [0]PETSC ERROR:
>>          User Tue Apr 24 22:30:31 2012
>>         /lib
>>         las-lapack=1
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: Invalid argument!
>>         [0]PETSC ERROR: Wrong type of object: Parameter # 1!
>>         [0]PETSC ERROR:
>>         shooting.
>>         [0]PETSC ERROR:
>>         /lib
>>         las-lapack=1
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: MatNullSpaceDestroy() line 305 in
>>         C-~1\src\mat\INTERF~1\matnull.c
>>         [0]PETSC ERROR: ourdmfunction() line 30 in
>>         src/dm/interface/ftn-custom/C:\temp\P
>>         ETSC-~1\src\dm\INTERF~1\FTN-CU~1\zdmf.c
>>         [0]PETSC ERROR: DMComputeFunction() line 1783 in
>>         src/dm/interface/C:\temp\PETSC-
>>         ~1\src\dm\INTERF~1\dm.c
>>         [0]PETSC ERROR: KSPSetUp() line 218 in
>>         src/ksp/ksp/interface/C:\temp\PETSC-~1\sr
>>         c\ksp\ksp\INTERF~1\itfunc.c
>>         [0]PETSC ERROR:
>>         shooting.
>>         [0]PETSC ERROR:
>>         /lib
>>         las-lapack=1
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR:
>>         shooting.
>>         [0]PETSC ERROR:
>>         /lib
>>         las-lapack=1
>>         --with-debuggin
>>         g=1 --useThreads=0
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: KSPSolve() line 402 in
>>         Vector Object:Vec_0000000084000000_0 1 MPI processes
>>           type: mpi
>>         Process [0]
>>         What's wrong?
>>         *program ex29f*
>>         implicit none
>>         !                    Include files
>>         !     petscsys.h  - base PETSc routines      petscvec.h - vectors
>>         !     petscmat.h - matrices
>>         !     petscksp.h    - Krylov subspace methods  petscpc.h  -
>>         preconditioners
>>         #include "finclude/petsc.h90"
>>         PetscErrorCode   ierr
>>         DM               da
>>         KSP              ksp
>>         Vec              x
>>         external         ComputeRHS,ComputeMatrix
>>         PetscInt i1,i3
>>         call  PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>         i3 = -4
>>         i1 = 1
>>         call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>         call
>>         DMDACreate2d(PETSC_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,i3,i3,PETSC_DECIDE,PETSC_DECIDE,i1,i1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>         call DMSetFunction(da,ComputeRHS,ierr)
>>         call DMSetJacobian(da,ComputeMatrix,ierr)
>>         call KSPSetDM(ksp,da,ierr)
>>         call KSPSetFromOptions(ksp,ierr)
>>         call KSPSetUp(ksp,ierr)
>>         call KSPSolve(ksp,PETSC_NULL_OBJECT,PETSC_NULL_OBJECT,ierr)
>>         call KSPGetSolution(ksp,x,ierr)
>>         call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>         call KSPDestroy(ksp,ierr)
>>         call DMDestroy(da,ierr)
>>         call PetscFinalize(ierr)
>>         end program ex29f
>>         subroutine ComputeRHS(da,x,b,ierr)
>>         implicit none
>>         PetscErrorCode  ierr
>>         PetscInt i,j,mx,my,xm,ym,xs,ys
>>         PetscScalar  h,nu,rho
>>         PetscScalar Hx,Hy
>>         PetscScalar,pointer :: array(:,:)
>>         Vec          x,b
>>         DM           da
>>         MatNullSpace nullspace    !>neumann BC
>>         nu = 0.1
>>         call
>>         DMDAGetInfo(da,PETSC_NULL_INTEGER,mx,my,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
>>         Hx = 1.d0 / (mx-1)
>>         Hy = 1.d0 / (my-1)
>>         call
>>         DMDAGetCorners(da,xs,ys,PETSC_NULL_INTEGER,xm,ym,PETSC_NULL_INTEGER,ierr)
>>         call DMDAVecGetArrayF90(da,b,array,ierr)
>>         do j = ys,ys+ym-1
>>             do i = xs,xs+xm-1
>>                 array(i,j) =
>>         exp(-(i*Hx)*(i*Hx)/nu)*exp(-(j*Hy)*(j*Hy)/nu)*Hx*Hy
>>             end do
>>         end do
>>         call DMDAVecRestoreArrayF90(da,b,array,ierr)
>>         call VecAssemblyBegin(b,ierr)
>>         call VecAssemblyEnd(b,ierr)
>>         !call
>>     4th argument should be PETSC_NULL_OBJECT.
>>        Matt
>>         !call MatNullSpaceRemove(nullspace,b,PETSC_NULL,ierr)
>>         !call MatNullSpaceDestroy(nullspace,ierr)
>>         end subroutine ComputeRHS
>>         subroutine ComputeMatrix(da,x,JJ,jac,str,ierr)
>>         implicit none
>>         Mat          jac,JJ
>>         PetscErrorCode    ierr
>>         DM           da
>>         PetscInt    i,j,k,mx,my,xm
>>         PetscInt    ym,xs,ys,i1,i5
>>         PetscScalar  v(5),Hx,Hy,rho,centerRho
>>         PetscScalar  HydHx
>>         PetscScalar  HxdHy
>>         MatStencil   row(4),col(4,5)
>>         Vec          x
>>         MatStructure str
>>         rho = 1.0
>>         i1 = 1
>>         i5 = 5
>>         centerRho = rho
>>         call
>>         Hx = 1.d0 / (mx-1)
>>         Hy = 1.d0 / (my-1)
>>         HxdHy = Hx/Hy
>>         HydHx = Hy/Hx
>>         call
>>         do j=ys,ys+ym-1
>>             do i=xs,xs+xm-1
>>                 row(MatStencil_i) = i
>>                 row(MatStencil_j) = j
>>                 call ComputeRho(i,j,mx,my,centerRho,rho)
>>                 if (i.eq.0 .or. j.eq.0 .or. i.eq.mx-1 .or. j.eq.my-1)
>>         then
>>                     v(1) = 2.0*rho*(HxdHy + HydHx)
>>                     call
>>         MatSetValuesStencil(jac,i1,row,i1,row,v,INSERT_VALUES,ierr)
>>                 else
>>                     v(1) = -rho*HxdHy
>>     Cut and paste error above.
>>       Matt
>>                     v(2) = -rho*HydHx
>>                     col(MatStencil_i,2) = i-1
>>                     v(3) = 2.0*rho*(HxdHy + HydHx)
>>                     col(MatStencil_i,3) = i
>>                     col(MatStencil_j,3) = j
>>                     v(4) = -rho*HydHx
>>                     col(MatStencil_i,4) = i+1
>>                     col(MatStencil_j,4) = j
>>                     v(5) = -rho*HxdHy
>>                     col(MatStencil_i,5) = i
>>                     col(MatStencil_j,5) = j+1
>>                     call
>>         MatSetValuesStencil(jac,i1,row,i5,col,v,INSERT_VALUES,ierr)
>>                 end if
>>             end do
>>         end do
>>         call MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY,ierr)
>>         call MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY,ierr)
>>         !call
>>         !call MatSetNullSpace(jac,nullspace,ierr)
>>         end subroutine ComputeMatrix
>>         subroutine ComputeRho(i,j,mx,my,centerRho,rho)
>>         PetscInt    i,j,mx,my
>>         PetscScalar  rho,centerRho
>>         if ((i > mx/3.0) .and. (i < 2.0*mx/3.0) .and. (j > my/3.0)
>>         .and. (j < 2.0*my/3.0)) then
>>             rho = centerRho
>>         else
>>             rho = 1.0
>>         end if
>>         end subroutine ComputeRho
>>         Yours sincerely,
>>         TAY wee-beng
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120426/59477d4e/attachment-0001.htm>
