[petsc-users] Error of petsc builde or the conflic between Petsc and intel-window Microsoft Visual Stud compiler
Wed May 11 14:03:46 CDT 2011
  This is a very strange error. To pointers are coming out to be 0 when there is no way they should ever be.
   First cd to src/vec/vec/examples/tutorials ; make ex1; ./ex1 does that run ok?
   Then cd src/snes/examples/tutorials; make ex19; ./ex19  does that crash (likely it will)
   Then you need to run either ex1 (if it crashed) or ex19 in the debugger to see how the pointers in the PetscMemcpy() are ending up being zero.
   One thought is that some incompatible system library is getting linked in. Are you sure the install of Developers studio is correct and there are not any old compiler libraries around? That is does a simple developers studio code compile and run correctly?
   Barry
On May 10, 2011, at 6:57 AM, Nguyen Hung Thanh wrote:
> Dear Petsc developers/users,
> It took a while for me to install Petsc, configure and used this library on Intel –Microsoft Visual platform. And, unfortunately I have not reached the goal yet. I am sorry for that I have again ask you some questions about Petsc configure/ running:
> 1)      I used the configure-options is
>  Hung at TRD-K-ST-008-PC ~/petsc-3.1-p7
> $ ./config/configure.py --with-cc='win32fe icl' --with-cxx='win32fe icl' --with
> -clanguage=cxx --with-fc=0   --with-mpi-include=/home/Hung/IntelMPI/MPI/4.0.1.0
> 07/ia32/include   --with-mpi-lib=/home/Hung/IntelMPI/MPI/4.0.1.007/ia32/lib/imp
> i.lib  --with-blas-lapack-dir=/home/Hung/IntelMKL/ia32/lib
> NB: impi
> The configure is seem ok.
> 2) And, check the Petcs libraries working :$ make  PETSC_DIR=/home/Hung/petsc-3.1-p7 PETSC_ARCH=cygwin-cxx-debug test
> Running test examples to verify correct installation
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> [0]PETSC ERROR: --------------------- Error Message ----------------------------
> [0]PETSC ERROR: Arguments are incompatible!
> [0]PETSC ERROR: Memory regions overlap: either use PetscMemmov()
>               or make sure your copy regions and lengths are correct.
>               Length (bytes) 64 first address 0 second address 0!
> [0]PETSC ERROR: ----------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 20
> 10
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: C:\cygwin\home\Hung\petsc-3.1-p7\src\snes\examples\tutorials\ex1
> 9.exe on a cygwin-cx named TRD-K-ST-008-PC by Hung Tue May 10 13:35:26 2011
> [0]PETSC ERROR: Libraries linked from /home/Hung/petsc-3.1-p7/cygwin-cxx-debug/l
> ib
> [0]PETSC ERROR: Configure run at Tue May 10 11:28:56 2011
> [0]PETSC ERROR: Configure options --with-cc="win32fe icl" --with-cxx="win32fe ic
> l" --with-clanguage=cxx --with-fc=0 --with-mpi-include=/home/Hung/IntelMPI/MPI/4
> .0.1.007/ia32/include --with-mpi-lib=/home/Hung/IntelMPI/MPI/4.0.1.007/ia32/lib/
> impi.lib --with-blas-lapack-dir=/home/Hung/IntelMKL/ia32/lib --useThreads=0
> [0]PETSC ERROR: User provided function() line 1755 in src/vec/is/impls/block/C:\
> cygwin\home\Hung\PETSC-~1.1-P\include\petscsys.h
> [0]PETSC ERROR: ISCreateBlock() line 296 in src/vec/is/impls/block/C:\cygwin\hom
> e\Hung\PETSC-~1.1-P\src\vec\is\impls\block\block.c
> [0]PETSC ERROR: DACreate_2D() line 1463 in src/dm/da/src/C:\cygwin\home\Hung\PET
> SC-~1.1-P\src\dm\da\src\da2.c
> [0]PETSC ERROR: DASetType() line 48 in src/dm/da/src/C:\cygwin\home\Hung\PETSC-~
> 1.1-P\src\dm\da\src\dareg.c
> [0]PETSC ERROR: DASetTypeFromOptions_Private() line 65 in src/dm/da/src/C:\cygwi
> n\home\Hung\PETSC-~1.1-P\src\dm\da\src\dacreate.c
> [0]PETSC ERROR: DASetFromOptions() line 131 in src/dm/da/src/C:\cygwin\home\Hung
> [0]PETSC ERROR: DACreate2d() line 1847 in src/dm/da/src/C:\cygwin\home\Hung\PETS
> [0]PETSC ERROR: main() line 107 in src/snes/examples/tutorials/C:\cygwin\home\Hu
> ng\PETSC-~1.1-P\src\snes\examples\TUTORI~1\ex19.c
> application called MPI_Abort(MPI_COMM_WORLD, 75) - process 0
> job aborted:
> rank: node: exit code[: error message]
> 0: TRD-K-ST-008-PC.petrell.local: 75: process 0 exited without calling finalize
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI process
> es.....
> Completed test examples
> Please, tell me  how  I can  solve the problem,
> Regards
> Hung T Nguyen
> Numerical analys
> Physis Derpart.
> UiTø, Tromsø Norway
