[petsc-users] SPAI preconditioner in PETSc
Jed Brown jed at 59A2.org
Tue May 10 07:21:28 CDT 2011
On Tue, May 10, 2011 at 14:18, Danesh Daroui <danesh.daroui at ltu.se> wrote:
> Thanks Jed. Can I have both implementations of SPAI and use each of them
> whenever I want or I just can have one at time?
Absolutely. You can install PETSc with every external package you might
possibly ever want to use, then choose which one you use on any particular
run (or per-object if your code solves multiple systems) at run-time with
options like -pc_type.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110510/09b11894/attachment.htm>
