[petsc-users] Using HYPRE AMG for only one of the linear eqns
Sat Dec 24 08:14:40 CST 2011
On Sat, Dec 24, 2011 at 8:11 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Hi,
> No I'm not. Will using ptype2 or ksptype2 work?
I think you should setup
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/PC/PCFIELDSPLIT.html
probably using
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/PC/PCFieldSplitSetIS.html#PCFieldSplitSetIS
     Matt
> Yours sincerely,
> TAY wee-beng
> On 24/12/2011 3:07 PM, Matthew Knepley wrote:
> On Sat, Dec 24, 2011 at 7:42 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I am solving 4 linear equations in my cfd code. I have declared them as:
>> KSP   ksp,ksp_semi_x,ksp_semi_y,ksp_semi_z
>> PC    pc,pc_semi_x,pc_semi_y,pc_semi_z
>> PCType      ptype
>> KSPType        ksptype
>> However, I only want to solve the 1st eqn via hypre (thru command
>> prompt), and the others via KSPBCGS.
>> I now add:
>> ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
>> Are all the eqns now solved using hypre?
>> How should I specify in the command prompt?
>  Are you using DMDA? If so, its easy to do PCFIELDSPLIT from the command
> line.
>     Matt
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111224/92089921/attachment.htm>
