[petsc-users] Using HYPRE AMG for only one of the linear eqns
TAY wee-beng zonexo at gmail.com
Sat Dec 24 08:11:55 CST 2011
No I'm not. Will using ptype2 or ksptype2 work?
Yours sincerely,
TAY wee-beng
On 24/12/2011 3:07 PM, Matthew Knepley wrote:
> On Sat, Dec 24, 2011 at 7:42 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I am solving 4 linear equations in my cfd code. I have declared
>     them as:
>     KSP   ksp,ksp_semi_x,ksp_semi_y,ksp_semi_z
>     PC    pc,pc_semi_x,pc_semi_y,pc_semi_z
>     PCType      ptype
>     KSPType        ksptype
>     However, I only want to solve the 1st eqn via hypre (thru command
>     prompt), and the others via KSPBCGS.
>     I now add:
>     ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
>     Are all the eqns now solved using hypre?
>     How should I specify in the command prompt?
> Are you using DMDA? If so, its easy to do PCFIELDSPLIT from the
> command line.
>    Matt
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111224/80e0206f/attachment-0001.htm>
