[petsc-users] Using HYPRE AMG for only one of the linear eqns
Sat Dec 24 09:03:20 CST 2011
On Sat, Dec 24, 2011 at 07:42, TAY wee-beng <zonexo at gmail.com> wrote:
> I am solving 4 linear equations in my cfd code. I have declared them as:
> KSP   ksp,ksp_semi_x,ksp_semi_y,ksp_**semi_z
> PC    pc,pc_semi_x,pc_semi_y,pc_**semi_z
> PCType      ptype
> KSPType        ksptype
> However, I only want to solve the 1st eqn via hypre (thru command prompt),
> and the others via KSPBCGS.
> I now add:
> ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
> Are all the eqns now solved using hypre?
> How should I specify in the command prompt?
As Matt says, you can use PCFIELDSPLIT to solve the coupled system. If you
really want to set up your own KSP for each system, then use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetOptionsPrefix.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111224/7dd1329e/attachment.htm>
