[petsc-users] Bug with 4.6.2
Fri Dec 2 09:34:50 CST 2011
On Fri, Dec 2, 2011 at 9:31 AM, Parker, Andrew (UK Filton) <
Andrew.Parker2 at baesystems.com> wrote:
> Hi,****
> I appreciate that this tool may not be supported yet, but I get a compile
> error with gcc 4.6.2****
> petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: 'VecType' does not
> name a type****
> petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: ISO C++ forbids
> declaration of 'parameter' with no type [-fpermissive]****
> Any thoughts on how I fix this locally? But more generally needs to be
> fixed.
You have to send the entire message. I cannot even see which file is being
compiled here. Also,
is the GPU stuff turned on?
  Matt
> Cheers,****
> Andy****
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/cff65ab1/attachment.htm>
