[petsc-users] Bug with 4.6.2
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Fri Dec 2 09:31:58 CST 2011
I appreciate that this tool may not be supported yet, but I get a
compile error with gcc 4.6.2
petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: 'VecType' does not
name a type
petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: ISO C++ forbids
declaration of 'parameter' with no type [-fpermissive]
Any thoughts on how I fix this locally? But more generally needs to be
fixed.
Cheers,
Andy
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/e3da1fe9/attachment.htm>
