[petsc-users] Bug with 4.6.2
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Fri Dec 2 09:39:09 CST 2011
Not sure what you mean, it's been including form a file I've used
somewhere, but the c++ type is undefined in that file....
It doesn't know what vectype is...
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: 02 December 2011 15:35
To: PETSc users list
Subject: Re: [petsc-users] Bug with 4.6.2
                    *** WARNING ***
  This message has originated outside your organisation,
  either from an external partner or the Global Internet.
      Keep this in mind if you answer this message.
On Fri, Dec 2, 2011 at 9:31 AM, Parker, Andrew (UK Filton)
<Andrew.Parker2 at baesystems.com> wrote:
	I appreciate that this tool may not be supported yet, but I get
a compile error with gcc 4.6.2
	petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: 'VecType'
does not name a type
	petsc/petsc-3.2-p5/include/petscdm.h:138:47: error: ISO C++
forbids declaration of 'parameter' with no type [-fpermissive]
	Any thoughts on how I fix this locally? But more generally needs
to be fixed.
You have to send the entire message. I cannot even see which file is
being compiled here. Also,
is the GPU stuff turned on?
  Matt
	Cheers,
	Andy
	This email and any attachments are confidential to the intended
	recipient and may also be privileged. If you are not the
intended
	recipient please delete it from your system and notify the
sender.
	You should not copy it or use it for any purpose nor disclose or
	distribute its contents to any other person.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/a55990ff/attachment.htm>
