HDF5 and DA ndof > 1
Wed Sep 2 15:00:39 CDT 2009
Easiest thing to do is isolate the changeset - and grab the diff - and
apply to petsc-3.0.0.
If you know the changeset id [or the app lines that belong to this
changeset] - I can take a look.
If its multiple changesets for this fix - then we'll have to
find/extract them all.. [finding all might be tricky]
Satish
On Wed, 2 Sep 2009, Barry Smith wrote:
>  It may be possible to make the changes to 3.0.0 (by simply diffing with
> petsc-dev) but I don't have time to do it.
>   Barry
> On Sep 2, 2009, at 2:49 PM, Lisandro Dalcin wrote:
> > On Wed, Sep 2, 2009 at 2:12 PM, Barry Smith<bsmith at mcs.anl.gov> wrote:
> > > Juha,
> > >   You will need to switch to petsc-dev to have this ability. This fix
> > > won't
> > > get backported to petsc-3.0.0
> > > If you have trouble with petsc-dev let us know at petsc-maint at mcs.anl.gov
> > The problem for Juha is not likely petsc-dev, but building latest TAO
> > 1.10 against petsc-dev...
> > >  Barry
> > > On Sep 2, 2009, at 7:23 AM, Juha Jäykkä wrote:
> > > > Hi all!
> > > > I noticed a bug in 3.0.0-p8/src/dm/da/src/gr2.c, which causes the DA
> > > > vector to
> > > > be saved incorrectly into the hdf5 file.
> > > > However, this seems to be fixed in the latest nightly build, so my
> > > > question
> > > > is, how usable is the nightly or when will the -p9 come out with working
> > > > HDF5
> > > > DA saving when ndof>1?
> > > > Cheers,
> > > > Juha
> > Lisandro Dalcín
> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > Tel/Fax: +54-(0)342-451.1594
