HDF5 and DA ndof > 1
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep  2 14:53:43 CDT 2009
   It may be possible to make the changes to 3.0.0 (by simply diffing
with petsc-dev) but I don't have time to do it.
    Barry
On Sep 2, 2009, at 2:49 PM, Lisandro Dalcin wrote:
> On Wed, Sep 2, 2009 at 2:12 PM, Barry Smith<bsmith at mcs.anl.gov> wrote:
>>  Juha,
>>    You will need to switch to petsc-dev to have this ability. This
>> fix won't
>> get backported to petsc-3.0.0
>> If you have trouble with petsc-dev let us know at petsc-maint at mcs.anl.gov
> The problem for Juha is not likely petsc-dev, but building latest TAO
> 1.10 against petsc-dev...
>>   Barry
>> On Sep 2, 2009, at 7:23 AM, Juha Jäykkä wrote:
>>> Hi all!
>>> I noticed a bug in 3.0.0-p8/src/dm/da/src/gr2.c, which causes the DA
>>> vector to
>>> be saved incorrectly into the hdf5 file.
>>> However, this seems to be fixed in the latest nightly build, so my
>>> question
>>> is, how usable is the nightly or when will the -p9 come out with
>>> working
>>> HDF5
>>> DA saving when ndof>1?
>>> Cheers,
>>> Juha
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
