UMFPACK out of memory
Tue Oct 27 11:00:41 CDT 2009
On Tue, Oct 27, 2009 at 10:56 AM, francois pacull <fpacull at fluorem.com>wrote:
> Thank you Matt for your quick reply.
> I will try to use MUMPS soon. About UMFPACK, the OS used is a 64-bit Linux
> one. Also, we do have 64-bit pointers from what I understand; the following
> lines are from the PETSc configure.log file:
> #ifndef PETSC_SIZEOF_VOID_P
> #define PETSC_SIZEOF_VOID_P 8
> #endif
Yes, then it appears that UMFPACK cannot be used for large memory. Did you
try MUMPS?
  Matt
> And here is the umfpack_UMF_report_info from the subdomain that crashed:
> UMFPACK V5.4.0 (May 20, 2009), Info:
>   matrix entry defined as:          double
>   Int (generic integer) defined as: int
>   BLAS library used: Fortran BLAS.  size of BLAS integer: 4
>   MATLAB:                           no.
>   CPU timer:                        POSIX times ( ) routine.
>   number of rows in matrix A:       79002
>   number of columns in matrix A:    79002
>   entries in matrix A:              12030970
>   memory usage reported in:         8-byte Units
>   size of int:                      4 bytes
>   size of UF_long:                  8 bytes
>   size of pointer:                  8 bytes
>   size of numerical entry:          8 bytes
>   strategy used:                    unsymmetric
>   ordering used:                    colamd on A
>   modify Q during factorization:    yes
>   prefer diagonal pivoting:         no
>   pivots with zero Markowitz cost:               0
>   submatrix S after removing zero-cost pivots:
>       number of "dense" rows:                    0
>       number of "dense" columns:                 0
>       number of empty rows:                      0
>       number of empty columns                    0
>       submatrix S square and diagonal preserved
>   symbolic factorization defragmentations:       0
>   symbolic memory usage (Units):                 27435792
>   symbolic memory usage (MBytes):                209.3
>   Symbolic size (Units):                         177636
>   Symbolic size (MBytes):                        1
>   symbolic factorization CPU time (sec):         4.95
>   symbolic factorization wallclock time(sec):    4.95
>   symbolic/numeric factorization:      upper bound               actual
>   variable-sized part of Numeric object:
>       initial size (Units)                31236744                    -
>       peak size (Units)                  597607658                    -
>       final size (Units)                 550474688                    -
>   Numeric final size (Units)             550988250                    -
>   Numeric final size (MBytes)               4203.7                    -
>   peak memory usage (Units)              598718594                    -
>   peak memory usage (MBytes)                4567.9                    -
>   numeric factorization flops          1.63141e+12                    -
>   nz in L (incl diagonal)                171352664                    -
>   nz in U (incl diagonal)                346187947                    -
>   nz in L+U (incl diagonal)              517461609                    -
>   largest front (# entries)               15783705                    -
>   largest # rows in front                     2815                    -
>   largest # columns in front                  5607                    -
> UMFPACK V5.4.0 (May 20, 2009): ERROR: out of memory
> Thanks again,
> francois.
> Matthew Knepley a écrit :
>  On Tue, Oct 27, 2009 at 10:12 AM, francois pacull <fpacull at fluorem.com<mailto:
>> fpacull at fluorem.com>> wrote:
>>    Dear PETSc team,
>>    I have a few questions... During the resolution of a linear system
>>    in parallel, I am trying to apply a local LU solver to each of the
>>    SEQaij diagonal blocks of a MPIaij matrix partitioned with PARMETIS.
>>    - I started with MUMPS but it seems that it only works with
>>    unpartitioned aij matrices, is it really the case? Or could we use
>>    MUMPS to build an additive Schwarz preconditioner for example?
>> You can use MUMPS for the subproblem solver.
>>    - Then I tried UMFPACK. This works fine when the diagonal blocks
>>    (and the memory required to store the factors) are small but
>>    crashes when they are a little bit larger. For example with a
>>    "numeric final size" of 4203.7 MBytes,  I got the following
>>    message "ERROR: out of memory" while there was plenty of memory
>>    left in the computer. I tried either with the UMFPACK version 5.2,
>>    downloaded by PETSc, or with a manually installed version 5.4,
>>    linked to PETSc. Is this a behavior from UMFPACK that you already
>>    experienced?
>> Send all the error output. However, in oder to address more than 4G, you
>> will need 64-bit pointers.
>>    - Since UMFPACK seemed to have a memory limit around 4096 MB,  I
>>    tried to install a PETSc version with the option
>>    "--with-64-bit-indices", however none of the partitioning packages
>>    could be compiled with this option
>>    (parmetis,chaco,jostle,party,scotch). Is there a way to compile
>>    PETSc with 64 bit indices AND a partitioning package?
>> Not that I know of.
>>    - Finally, I tried to modify the PETSc source code umfpack.c so
>>    that it would deal with 64 bit indices, but I only ended up so far
>>    with a segmentation violation message at the execution... Is it
>>    the only way I could use UMPACK with large sparse matrices?
>> Why not just upgrade to a 64-bit OS if you want to address so much memory
>> on a single machine?
>>  Matt
>>    Thank you,
>>    Regards,
>>    francois pacull.
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091027/d9a011e3/attachment.htm>
