UMFPACK out of memory
francois pacull fpacull at fluorem.com
Tue Oct 27 14:06:35 CDT 2009
Yes Matt, MUMPS as the subproblem solver works well. I think that when I
tried it earlier, I forgot to convert my seqbaij submatrices into seqaij
ones...
Thanks, francois.
ps: for information to the community, I had  at first a similar problem
as when using UMFPACK (crashed when a submatrix is large) because of the
default MUMPS reordering mat_mumps_icntl_7 option that was set to METIS.
After switching to PORD, the problem was solved.
Matthew Knepley a écrit :
> On Tue, Oct 27, 2009 at 10:56 AM, francois pacull <fpacull at fluorem.com
> <mailto:fpacull at fluorem.com>> wrote:
>     Thank you Matt for your quick reply.
>     I will try to use MUMPS soon. About UMFPACK, the OS used is a
>     64-bit Linux one. Also, we do have 64-bit pointers from what I
>     understand; the following lines are from the PETSc configure.log file:
>     #ifndef PETSC_SIZEOF_VOID_P
>     #define PETSC_SIZEOF_VOID_P 8
>     #endif
> Yes, then it appears that UMFPACK cannot be used for large memory. Did
> you try MUMPS?
>   Matt
>     And here is the umfpack_UMF_report_info from the subdomain that
>     crashed:
>     UMFPACK V5.4.0 (May 20, 2009), Info:
>       matrix entry defined as:          double
>       Int (generic integer) defined as: int
>       BLAS library used: Fortran BLAS.  size of BLAS integer: 4
>       MATLAB:                           no.
>       CPU timer:                        POSIX times ( ) routine.
>       number of rows in matrix A:       79002
>       number of columns in matrix A:    79002
>       entries in matrix A:              12030970
>       memory usage reported in:         8-byte Units
>       size of int:                      4 bytes
>       size of UF_long:                  8 bytes
>       size of pointer:                  8 bytes
>       size of numerical entry:          8 bytes
>       strategy used:                    unsymmetric
>       ordering used:                    colamd on A
>       modify Q during factorization:    yes
>       prefer diagonal pivoting:         no
>       pivots with zero Markowitz cost:               0
>       submatrix S after removing zero-cost pivots:
>           number of "dense" rows:                    0
>           number of "dense" columns:                 0
>           number of empty rows:                      0
>           number of empty columns                    0
>           submatrix S square and diagonal preserved
>       symbolic factorization defragmentations:       0
>       symbolic memory usage (Units):                 27435792
>       symbolic memory usage (MBytes):                209.3
>       Symbolic size (Units):                         177636
>       Symbolic size (MBytes):                        1
>       symbolic factorization CPU time (sec):         4.95
>       symbolic factorization wallclock time(sec):    4.95
>       symbolic/numeric factorization:      upper bound
>     actual      %
>       variable-sized part of Numeric object:
>           initial size (Units)                31236744
>           peak size (Units)                  597607658
>           final size (Units)                 550474688
>       Numeric final size (Units)             550988250
>       Numeric final size (MBytes)               4203.7
>       peak memory usage (Units)              598718594
>       peak memory usage (MBytes)                4567.9
>       numeric factorization flops          1.63141e+12
>       nz in L (incl diagonal)                171352664
>       nz in U (incl diagonal)                346187947
>       nz in L+U (incl diagonal)              517461609
>       largest front (# entries)               15783705
>       largest # rows in front                     2815
>       largest # columns in front                  5607
>     UMFPACK V5.4.0 (May 20, 2009): ERROR: out of memory
>     Thanks again,
>     francois.
>         On Tue, Oct 27, 2009 at 10:12 AM, francois pacull
>         <fpacull at fluorem.com <mailto:fpacull at fluorem.com>
>         <mailto:fpacull at fluorem.com <mailto:fpacull at fluorem.com>>> wrote:
>            Dear PETSc team,
>            I have a few questions... During the resolution of a linear
>         system
>            in parallel, I am trying to apply a local LU solver to each
>         of the
>            SEQaij diagonal blocks of a MPIaij matrix partitioned with
>         PARMETIS.
>            - I started with MUMPS but it seems that it only works with
>            unpartitioned aij matrices, is it really the case? Or could
>         we use
>            MUMPS to build an additive Schwarz preconditioner for example?
>         You can use MUMPS for the subproblem solver.
>            - Then I tried UMFPACK. This works fine when the diagonal
>         blocks
>            (and the memory required to store the factors) are small but
>            crashes when they are a little bit larger. For example with a
>            "numeric final size" of 4203.7 MBytes,  I got the following
>            message "ERROR: out of memory" while there was plenty of memory
>            left in the computer. I tried either with the UMFPACK
>         version 5.2,
>            downloaded by PETSc, or with a manually installed version 5.4,
>            linked to PETSc. Is this a behavior from UMFPACK that you
>         already
>            experienced?
>         Send all the error output. However, in oder to address more
>         than 4G, you will need 64-bit pointers.
>            - Since UMFPACK seemed to have a memory limit around 4096
>         MB,  I
>            tried to install a PETSc version with the option
>            "--with-64-bit-indices", however none of the partitioning
>         packages
>            could be compiled with this option
>            (parmetis,chaco,jostle,party,scotch). Is there a way to compile
>            PETSc with 64 bit indices AND a partitioning package?
>         Not that I know of.
>            - Finally, I tried to modify the PETSc source code umfpack.c so
>            that it would deal with 64 bit indices, but I only ended up
>         so far
>            with a segmentation violation message at the execution... Is it
>            the only way I could use UMPACK with large sparse matrices?
>         Why not just upgrade to a 64-bit OS if you want to address so
>         much memory on a single machine?
>          Matt
>            Thank you,
>            Regards,
>            francois pacull.
>         What most experimenters take for granted before they begin
>         their experiments is infinitely more interesting than any
>         results to which their experiments lead.
>         -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
