UMFPACK out of memory
francois pacull fpacull at fluorem.com
Tue Oct 27 10:56:06 CDT 2009
Thank you Matt for your quick reply.
I will try to use MUMPS soon. About UMFPACK, the OS used is a 64-bit
Linux one. Also, we do have 64-bit pointers from what I understand; the
following lines are from the PETSc configure.log file:
#ifndef PETSC_SIZEOF_VOID_P
#define PETSC_SIZEOF_VOID_P 8
#endif
And here is the umfpack_UMF_report_info from the subdomain that crashed:
UMFPACK V5.4.0 (May 20, 2009), Info:
    matrix entry defined as:          double
    Int (generic integer) defined as: int
    BLAS library used: Fortran BLAS.  size of BLAS integer: 4
    MATLAB:                           no.
    CPU timer:                        POSIX times ( ) routine.
    number of rows in matrix A:       79002
    number of columns in matrix A:    79002
    entries in matrix A:              12030970
    memory usage reported in:         8-byte Units
    size of int:                      4 bytes
    size of UF_long:                  8 bytes
    size of pointer:                  8 bytes
    size of numerical entry:          8 bytes
    strategy used:                    unsymmetric
    ordering used:                    colamd on A
    modify Q during factorization:    yes
    prefer diagonal pivoting:         no
    pivots with zero Markowitz cost:               0
    submatrix S after removing zero-cost pivots:
        number of "dense" rows:                    0
        number of "dense" columns:                 0
        number of empty rows:                      0
        number of empty columns                    0
        submatrix S square and diagonal preserved
    symbolic factorization defragmentations:       0
    symbolic memory usage (Units):                 27435792
    symbolic memory usage (MBytes):                209.3
    Symbolic size (Units):                         177636
    Symbolic size (MBytes):                        1
    symbolic factorization CPU time (sec):         4.95
    symbolic factorization wallclock time(sec):    4.95
    symbolic/numeric factorization:      upper bound
actual      %
    variable-sized part of Numeric object:
        initial size (Units)                31236744
        peak size (Units)                  597607658
        final size (Units)                 550474688
    Numeric final size (Units)             550988250
    Numeric final size (MBytes)               4203.7
    peak memory usage (Units)              598718594
    peak memory usage (MBytes)                4567.9
    numeric factorization flops          1.63141e+12
    nz in L (incl diagonal)                171352664
    nz in U (incl diagonal)                346187947
    nz in L+U (incl diagonal)              517461609
    largest front (# entries)               15783705
    largest # rows in front                     2815
    largest # columns in front                  5607
UMFPACK V5.4.0 (May 20, 2009): ERROR: out of memory
Thanks again,
francois.
Matthew Knepley a écrit :
> On Tue, Oct 27, 2009 at 10:12 AM, francois pacull <fpacull at fluorem.com
> <mailto:fpacull at fluorem.com>> wrote:
>     Dear PETSc team,
>     I have a few questions... During the resolution of a linear system
>     in parallel, I am trying to apply a local LU solver to each of the
>     SEQaij diagonal blocks of a MPIaij matrix partitioned with PARMETIS.
>     - I started with MUMPS but it seems that it only works with
>     unpartitioned aij matrices, is it really the case? Or could we use
>     MUMPS to build an additive Schwarz preconditioner for example?
> You can use MUMPS for the subproblem solver.
>     - Then I tried UMFPACK. This works fine when the diagonal blocks
>     (and the memory required to store the factors) are small but
>     crashes when they are a little bit larger. For example with a
>     "numeric final size" of 4203.7 MBytes,  I got the following
>     message "ERROR: out of memory" while there was plenty of memory
>     left in the computer. I tried either with the UMFPACK version 5.2,
>     downloaded by PETSc, or with a manually installed version 5.4,
>     linked to PETSc. Is this a behavior from UMFPACK that you already
>     experienced?
> Send all the error output. However, in oder to address more than 4G,
> you will need 64-bit pointers.
>     - Since UMFPACK seemed to have a memory limit around 4096 MB,  I
>     tried to install a PETSc version with the option
>     "--with-64-bit-indices", however none of the partitioning packages
>     could be compiled with this option
>     (parmetis,chaco,jostle,party,scotch). Is there a way to compile
>     PETSc with 64 bit indices AND a partitioning package?
> Not that I know of.
>     - Finally, I tried to modify the PETSc source code umfpack.c so
>     that it would deal with 64 bit indices, but I only ended up so far
>     with a segmentation violation message at the execution... Is it
>     the only way I could use UMPACK with large sparse matrices?
> Why not just upgrade to a 64-bit OS if you want to address so much
> memory on a single machine?
>   Matt
>     Thank you,
>     Regards,
>     francois pacull.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
