a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Yin Feng yfeng1 at tigers.lsu.edu
Sun Oct 11 21:59:44 CDT 2009
The completed code is:
void PETSc(double mat[],double vec[],double sol[],long N,double tol) {
Vec            x,b;
Mat            A;
KSP            ksp;
PC             pc;
PetscInt       i,j,col[N];
PetscScalar    value[N];
PetscScalar    val;
 PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
VecCreate(PETSC_COMM_WORLD,&x);
VecSetSizes(x,PETSC_DECIDE,N);
VecSetFromOptions(x);
VecDuplicate(x,&b);
 MatCreate(PETSC_COMM_WORLD,&A);
MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
MatSetFromOptions(A);
 for (i=0; i<N; i++) {
for (j=0;j<N;j++) {
value[j]=mat[i*N+j];
col[j]=j;
MatSetValues(A,1,&i,N,col,value,INSERT_VALUES);
 MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
val=vec[i];
VecSetValues(b,1,&i,&val,INSERT_VALUES);
val=sol[i];
VecSetValues(x,1,&i,&val,INSERT_VALUES);
 VecAssemblyBegin(b);
VecAssemblyEnd(b);
 KSPCreate(PETSC_COMM_WORLD,&ksp);
KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
KSPGetPC(ksp,&pc);
        KSPSetType(ksp, KSPGMRES);
        PCSetType(pc,  PCBJACOBI);
 KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
  KSPSetFromOptions(ksp);
  KSPSolve(ksp,b,x);
  for (i=0;i<N;i++) {
      VecGetValues(x,1,&i,&sol[i]);
  VecDestroy(x);
  VecDestroy(b);
  MatDestroy(A);
  KSPDestroy(ksp);
  PetscFinalize();
Once this function is call in a loop, it reports error.
On Sun, Oct 11, 2009 at 9:38 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
> I put PETSc solver in one function and use another function to call that.This
> problem only appears when I put the function with PETSc solver in a loop,
> it works well at first step, and reports error "An error occurred in
> at second time. The program is designed to support only one processor like:
> Vec            x,b;
> Mat            A;
> KSP            ksp;
> PC             pc;
> PetscScalar    val;
> VecDuplicate(x,&b);
> KSPGetPC(ksp,&pc);
>         KSPSolve(ksp,b,x);
>         VecDestroy(x);
>         VecDestroy(b);
>         MatDestroy(A);
>         KSPDestroy(ksp);
>         PetscFinalize();
> Any one has ideal about this?
> The detailed error description is:
> *** after MPI was finalized
> *** MPI_ERRORS_ARE_FATAL (goodbye)
> Abort before MPI_INIT completed successfully; not able to guarantee that
> all other processes were killed!
> Thank you so much in advance!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091011/12f69bb6/attachment.htm>
