a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Yin Feng yfeng1 at tigers.lsu.edu
Sun Oct 11 21:38:44 CDT 2009
I put PETSc solver in one function and use another function to call that.This
problem only appears when I put the function with PETSc solver in a loop,
it works well at first step, and reports error "An error occurred in
at second time. The program is designed to support only one processor like:
Vec            x,b;
Mat            A;
KSP            ksp;
PC             pc;
PetscInt       i,j,col[N];
PetscScalar    value[N];
PetscScalar    val;
 PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
VecCreate(PETSC_COMM_WORLD,&x);
VecSetSizes(x,PETSC_DECIDE,N);
VecSetFromOptions(x);
VecDuplicate(x,&b);
MatCreate(PETSC_COMM_WORLD,&A);
MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
MatSetFromOptions(A);
KSPCreate(PETSC_COMM_WORLD,&ksp);
KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
KSPGetPC(ksp,&pc);
        KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
        KSPSetFromOptions(ksp);
        KSPSolve(ksp,b,x);
        VecDestroy(x);
        VecDestroy(b);
        MatDestroy(A);
        KSPDestroy(ksp);
        PetscFinalize();
Any one has ideal about this?
The detailed error description is:
*** after MPI was finalized
*** MPI_ERRORS_ARE_FATAL (goodbye)
Abort before MPI_INIT completed successfully; not able to guarantee that all
other processes were killed!
Thank you so much in advance!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091011/798351b4/attachment.htm>
