a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Yaakoub El Khamra yelkhamra at gmail.com
Sun Oct 11 22:04:54 CDT 2009
This is for Mayank's project isn't it
Regards
Yaakoub El Khamra
On Sun, Oct 11, 2009 at 9:59 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
> The completed code is:
> void PETSc(double mat[],double vec[],double sol[],long N,double tol) {
> Vec            x,b;
> Mat            A;
> KSP            ksp;
> PC             pc;
> PetscInt       i,j,col[N];
> PetscScalar    value[N];
> PetscScalar    val;
> PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
> VecCreate(PETSC_COMM_WORLD,&x);
> VecSetSizes(x,PETSC_DECIDE,N);
> VecSetFromOptions(x);
> VecDuplicate(x,&b);
> MatCreate(PETSC_COMM_WORLD,&A);
> MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
> MatSetFromOptions(A);
> for (i=0; i<N; i++) {
> for (j=0;j<N;j++) {
> value[j]=mat[i*N+j];
> col[j]=j;
> MatSetValues(A,1,&i,N,col,value,INSERT_VALUES);
> MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
> val=vec[i];
> VecSetValues(b,1,&i,&val,INSERT_VALUES);
> val=sol[i];
> VecSetValues(x,1,&i,&val,INSERT_VALUES);
> VecAssemblyBegin(b);
> VecAssemblyEnd(b);
> KSPCreate(PETSC_COMM_WORLD,&ksp);
> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
> KSPGetPC(ksp,&pc);
>         KSPSetType(ksp, KSPGMRES);
>         PCSetType(pc,  PCBJACOBI);
>  KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
>   KSPSetFromOptions(ksp);
>   KSPSolve(ksp,b,x);
>   for (i=0;i<N;i++) {
>       VecGetValues(x,1,&i,&sol[i]);
>   VecDestroy(x);
>   VecDestroy(b);
>   MatDestroy(A);
>   KSPDestroy(ksp);
>   PetscFinalize();
> Once this function is call in a loop, it reports error.
> On Sun, Oct 11, 2009 at 9:38 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
>> I put PETSc solver in one function and use another function to call that.
>> This problem only appears when I put the function with PETSc solver in a
>> loop,
>> it works well at first step, and reports error "An error occurred in
>> at second time. The program is designed to support only one processor
>> like:
>> Vec            x,b;
>> Mat            A;
>> KSP            ksp;
>> PC             pc;
>> PetscScalar    val;
>> VecDuplicate(x,&b);
>> KSPGetPC(ksp,&pc);
>>         KSPSolve(ksp,b,x);
>>         VecDestroy(x);
>>         VecDestroy(b);
>>         MatDestroy(A);
>>         KSPDestroy(ksp);
>>         PetscFinalize();
>> Any one has ideal about this?
>> The detailed error description is:
>> *** after MPI was finalized
>> *** MPI_ERRORS_ARE_FATAL (goodbye)
>> Abort before MPI_INIT completed successfully; not able to guarantee that
>> all other processes were killed!
>> Thank you so much in advance!
