Matlab matrix writer
Fri Oct 9 18:10:22 CDT 2009
   The most likely cause is you are passing a non-sparse Matlab matrix
to the writer; it is then saving it as a dense array (vector) so PETSc
cannot read it.
Run the array through the Matlab sparse() function and make sure it is
sparse before you pass it to the save problem.
    Also make sure you have the latest patched PETSc.
    If this does not resolve the problem then email to petsc-maint at mcs.anl.gov
  the Matlab code that produces the "bad" binary file.
    Barry
On Oct 9, 2009, at 5:24 PM, Umut Tabak wrote:
> Dear developers/users,
> As a follow up for my previous question, if I use the matlab
> functions that come with the distribution, namely, PetscBinaryWrite
> m file, and try to read this matrix, I end up with
> [0]PETSC ERROR: Unexpected data in file!
> [0]PETSC ERROR: not matrix object in file!
> I am also checking further what is going wrong in the m file.
> Someone perhaps could answer faster.
> BR,
> Umut
