Reuse matrix and vector
Jed Brown jed at 59A2.org
Thu Nov 5 04:58:53 CST 2009
jarunan at ascomp.ch wrote:
>> I suspect you are using a stale preconditioner, but
>> MatMPIAIJSetPreallocationCSR should not be called every iteration.
> What do you mean 'stale preconditioner' ? I use Additive Schwarz.
That the preconditioner was not being updated when you change the
matrix.  If you reset everything inside the loop, then that isn't the
problem.
>> It's better to call this once at the beginning and update with
>> MatSetValues (insert one row at a time, it's very little code).
>> MatMPIAIJSetPreallocationCSR reallocates memory because it doesn't check
>> to see if the nonzero pattern has changed (because that's not what it's
>> for).
> Yes, thank you for the advice. I will modify this. But MatSetValues() is
> not efficient with a big problem. It takes much time.
No, either you are inserting values that have not been preallocated
(check with -info | grep mallocs) or you are inserting single values.
You should insert a full row every time you call MatSetValues.
>> Where are you calling KSPSetOperators?  You have to call this every time
>> the matrix changes.
> I did shortcut of the code, actually...just to put it here. After
> creating and setting Matrix and vector. In each loop I create the KSP:
>     call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>     call KSPSetOperators(ksp,Ap,Ap,DIFFERENT_NONZERO_PATTERN,ierr)
>     call KSPGetPC(ksp,pc,ierr)
>     call PCSetType(pc,pct,ierr)
>     if (pct == PCASM) then
>        call PCASMSetTotalSubdomains(pc,glob_nblocks_psc,PETSC_NULL_OBJECT,ierr)
>        call PCASMSetLocalSubdomains(pc,nblocks_psc,PETSC_NULL_OBJECT,ierr)
Only call one of these.
>        call PetscOptionsSetValue('-pc_asm_overlap','1',ierr)
>        call PetscOptionsSetValue('-sub_pc_type','lu',ierr)
>        call PetscOptionsSetValue('-sub_pc_factor_zeropivot','0.0',ierr)
>     endif
>     call KSPSetTolerances(ksp,resin,1.e-20,  &
>              PETSC_DEFAULT_DOUBLE_PRECISION,nswp_psc,ierr)
>     call KSPSetType(ksp,kspt,ierr)
>     call KSPSetFromOptions(ksp,ierr)
Of the above, only KSPSetOperators() should be called inside the loop,
everything else is setup that should happen before your loop.
>     call KSPSolve(ksp,rhs,sol,ierr)
>     call KSPDestroy(ksp,ierr)
How was your code, and the convergence different before?
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091105/0ea1ef14/attachment.pgp>
