Reuse matrix and vector
jarunan at ascomp.ch jarunan at ascomp.ch
Tue Nov 10 02:28:56 CST 2009
>> Yes, thank you for the advice. I will modify this. But MatSetValues() is
>> not efficient with a big problem. It takes much time.
> No, either you are inserting values that have not been preallocated
> (check with -info | grep mallocs) or you are inserting single values.
> You should insert a full row every time you call MatSetValues.
I have tried as you suggested: First allocate with
MatCreateMPIAIJWithArrays() then use MatSetValues() to reset the
matrix. MatSetValues() has great performance but
MatCreateMPIAIJWithArrays() need really long time to allocate the
matrix in the first iteration with more than 1 processor (With one
processor it is very fast).
Total number of cells is 744872, divided into 40 blocks. In one
processor, MatCreateMPIAIJWithArrays() takes 0.097 sec but 280 sec
with 4 processors. Usually, this routine has no problem with small
test case. It works the same for one or more than one processors.
in the first iteration.
     Mat Ap
     call MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,
istorf_no_ovcell,         &
       istorf_no_ovcell, PETSC_DETERMINE, PETSC_DETERMINE, rowind,
columnind,   &
       A, Ap, ierr)
     call MatAssemblyBegin(Ap,MAT_FINAL_ASSEMBLY,ierr)
     call MatAssemblyEnd(Ap,MAT_FINAL_ASSEMBLY,ierr)
After the first iteration, looping over the row. the whole row is set
at a time.
     call MatSetValues(Ap,1,row_impl,7,col_impl,a_impl,INSERT_VALUES,ierr)
Does the communication of MatCreateMPIAIJWithArrays() in parallel
computation cost a lot? What could be the cause that
MatCreateMPIAIJWithArrays() so slow in the first iteration?
Best reagards,
Jarunan
