Solving a singular matrix with BoomerAMG
Jed Brown jed at 59A2.org
Thu Nov 5 04:05:26 CST 2009
Thomas Witkowski wrote:
> I want so solve a system with a singular matrix (just the laplace
> discretized with the fem using pure Neumann boundary conditions) with
> BoomerAMG. Is there any way to do it directly in BoomerAMG/PETSc, or
> must I change the matrix to make it nonsingular?
The user's manual has a section on solving singular systems, you just
need to tell KSP about the null space (either with KSPSetNullSpace or
-ksp_constant_null_space).  Small known null spaces are rarely an issue
with iterative methods.  With multigrid, there is some risk that the
coarse operator is also singular; this can cause trouble since it is
usually solved with a direct solver, but should not happen in your case.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091105/ec2e983d/attachment.pgp>
